Speedbird Posted June 16, 2019 Report Share Posted June 16, 2019 Where can I get a repair kit for a Mooney M10 Cadet Master Brake Cylinder? Skyport has the whole assembly as part # 850095-000 Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 16, 2019 Report Share Posted June 16, 2019 First try Lasar... Dan is an excellent resource for bits and pieces... if they are available. -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2019 Report Share Posted June 16, 2019 Generally brake cylinders contain standard Mil spec O rings. Do you know who the cylinder manufacturer is? Clarence Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 17, 2019 Report Share Posted June 17, 2019 @Speedbird are you checking in? See response from the Doc, above... -a- Quote Link to comment Share on other sites More sharing options...
Igor_U Posted June 17, 2019 Report Share Posted June 17, 2019 On 6/15/2019 at 9:06 PM, Speedbird said: Where can I get a repair kit for a Mooney M10 Cadet Master Brake Cylinder? Skyport has the whole assembly as part # 850095-000 M10 Cadet is really ercoupe, right? Not many owners hang out here but Univair should have the parts, IIRC. Good luck. Quote Link to comment Share on other sites More sharing options...
