Niko182 Posted January 12, 2019 Report Posted January 12, 2019 anyone have a voltage regulator part number for the Ovation. My alternator died last week, and once the new one was installed, looks like the old alternator took out the voltage regulator with it. Just looking for the right part number or a possible fix / solution. The new alternator that replaced it was a 150amp vs the original 100amp one. I tagged some people that seem to know the the complete systems of the ovation/eagles in the back of their head. @LANCECASPER@StevenL757 1
LANCECASPER Posted January 12, 2019 Report Posted January 12, 2019 Here are the factory part numbers:
kortopates Posted January 12, 2019 Report Posted January 12, 2019 After you see what it cost to replace, consider the option of having it repaired. A firm in New York, Consolidated ..., has the capability to overhaul most 24v Mooney alternators. Call them with your verified part no and they can confirm.I could give you more contact info but traveling - living the Mooney dream out of country Sent from my iPhone using Tapatalk 1
carusoam Posted January 12, 2019 Report Posted January 12, 2019 Sounds like Paul may be referencing these guys...(?) https://www.consolac.com/capabilities/ Consolidated aircraft supply.... Ronkonkoma, NY. Best regards, -a- 1
Niko182 Posted January 12, 2019 Author Report Posted January 12, 2019 After looking up the topic, can they still be sent to maxwell? After finding out they sell for 1600 bucks, i was a bit shocked.
carusoam Posted January 12, 2019 Report Posted January 12, 2019 Paul Max visits often if you want to ask... @Pmaxwell OH question... Mooney Ovation Voltage regulator... Best regards, -a-
StevenL757 Posted January 13, 2019 Report Posted January 13, 2019 Yea, Lance @LANCECASPER beat me to it. I also came up with the 270 part to fit your SN (0010). Let me make a couple of calls in the morning to ask about sourcing and OH options and will check back in. Steve
Pmaxwell Posted January 13, 2019 Report Posted January 13, 2019 6 hours ago, carusoam said: Paul Max visits often if you want to ask... @Pmaxwell OH question... Mooney Ovation Voltage regulator... Best regards, -a- We repair them for a flat fee of $350. 1
Niko182 Posted January 13, 2019 Author Report Posted January 13, 2019 1 minute ago, Pmaxwell said: We repair them for a flat fee of $350. Could you give me a call or text? Nik 949 267 8813@Pmaxwell
carusoam Posted January 13, 2019 Report Posted January 13, 2019 Way to go, Paul! Thanks for the response. Best regards, -a-
StevenL757 Posted January 17, 2019 Report Posted January 17, 2019 On 1/11/2019 at 11:42 PM, Niko182 said: anyone have a voltage regulator part number for the Ovation. My alternator died last week, and once the new one was installed, looks like the old alternator took out the voltage regulator with it. Just looking for the right part number or a possible fix / solution. The new alternator that replaced it was a 150amp vs the original 100amp one. I tagged some people that seem to know the the complete systems of the ovation/eagles in the back of their head. @LANCECASPER@StevenL757 On 1/12/2019 at 7:59 PM, StevenL757 said: Yea, Lance @LANCECASPER beat me to it. I also came up with the 270 part to fit your SN (0010). Let me make a couple of calls in the morning to ask about sourcing and OH options and will check back in. Checking back in...I wasn't aware of a 150-amp alternator PMA available for the IO550G platform, unless it's from Hartzell Engine Technologies, but I can't recall seeing one made by them. The original IO550G alternators are made by Continental Motors, and they only type-certified a 100-amp option for that engine. Either way...did a bit more research and you have a few options. Not sure if you've had a chance to diagnose yet and if you're proficient with wiring (not just familiar...proficient), but before you are convinced you have a failed regulator, start with making sure there are no shorted wires between the alternator and the firewall, as the field wire can overheat and short. During the troubleshooting, make sure you have full voltage from the regulator...a few volts less than 24V is normal. Tracing the path E2E, the field wiring goes from the CB --> switch --> voltage regulator --> firewall --> alternator. If you aren't comfortable with troubleshooting (it gets tricky, as the wiring takes awhile to trace back), get ahold of LASAR or the folks at Top Gun, as they're fairly close to your location. My IA can also take you through the detailed process over the phone. If you have the Zeftronics A25 AEM voltage regulator installed, assuming worst-case, they are about $1200 new from an MSC and Paul @Pmaxwell has offered repair on your existing one if needed. Either way, happy to help out and let us know what you decide. I hope it's an inexpensive fix. Steve 1
Niko182 Posted January 17, 2019 Author Report Posted January 17, 2019 As of now its been sent to Maxwell. hopefully that's the solution and hopefully we should be back in the air Saturday if not Monday.
carusoam Posted January 17, 2019 Report Posted January 17, 2019 Niko, When you get some time... Check on the details regarding the 150Amps vs. 100Amps... Steven pointed out an interesting challenge regarding wire sizes.... If all the Amps start being used, the wires may get hotter than expected... PP thoughts only, I have little electro-mechanical experience... Best regards, -a-
Niko182 Posted January 17, 2019 Author Report Posted January 17, 2019 New wires were installed with the alternator. Will check again for grounding, but hoping the Regulator fixes the issue. Can't really troubleshoot without an essential part to the electrical system. 1
flyingscot Posted November 21, 2022 Report Posted November 21, 2022 Greetings all – I was hoping to update this thread — Anyone know / wish to comment on the current status/availability of replacement 24V voltage regulators for the ovation? Are there currently any PMA replacements available or is repair (e.g. Consolidated) the only option at this point? MSCs/Mooney don’t seem to have any stock, and haven’t for a long time, what are people doing now in 2022… Thanks — Bob PS I’m looking for P/N 800397–501
Niko182 Posted November 21, 2022 Author Report Posted November 21, 2022 Just now, FlyingScot said: Greetings all – I was hoping to update this thread — Anyone know / wish to comment on the current status/availability of replacement 24V voltage regulators for the ovation? Are there currently any PMA replacements available or is repair (e.g. Consolidated) the only option at this point? MSCs/Mooney don’t seem to have any stock, and haven’t for a long time, what are people doing now in 2022… Thanks — Bob PS I’m looking for P/N 800397–501 Maxwell fixes them. Id look that direction. I believe he charges 300 bucks. @Pmaxwell 1 1
carusoam Posted November 21, 2022 Report Posted November 21, 2022 +1 for DMax and company for repairs… Now may be the time to ask questions…. If you have a single alternator system… and are considering a two alternator system….??? PP thoughts only, -a- 1
flyingscot Posted November 21, 2022 Report Posted November 21, 2022 1 hour ago, carusoam said: +1 for DMax and company for repairs… Now may be the time to ask questions…. If you have a single alternator system… and are considering a two alternator system….??? PP thoughts only, -a- I am - I'm all-electric - had the Vac system pulled a while ago when I did a panel upgrade so I have a couple of free engine accessory drive pads B&C still doesn't have an STC for an M20, but I understand field approvals aren't hard to come by (famous last words). I don't think I would try to split the busses to try to create an emergency bus, though, I would just make it a failover. My steady-state draw in flight seems to be around 20A, which at worst with a 20A standby alternator would mean a very slowly draining battery. 1
