  On 1/7/2022 at 8:16 AM, Jerry 5TJ said:
A diversity transponder uses two antennas, one on top of the airplane and one below. Probably not needed in the USA in the near term but many countries including Canada are scheduled to require diversity transponders to permit satellites to replace ground radar sites.
Expand
Are you talking about ADS-B out? I am installing Dynon’s Mode S transponder that will read it’s position from GPS
never mind. Reading about it right now
Expand
Yes, ADS-B out is accomplished by Mode S ES (or 978 UAT in the USA).
Mode S coverage from Aireon satellites
https://aireon.com
requires a transponder antenna on top of the airplane.
Diversity transponders have two transponder antennas, top and bottom.
  On 1/7/2022 at 4:17 AM, Nokomis449 said:
I am ashamed of each and every one of you.  @Skates97 started this post over 3 years ago and not ONE PERSON has asked him how many knots he gained.
I'm guessing 10 but I tend to be MooneyConservative.
Antenna.thumb.jpg.3f2d6b4ebc27bd0032ddb2c052e2c4b8.jpg.7beed60d0439751312bd28b58b13722c.jpg
Expand
I prefer not to disclose it as it might embarrass too many members...:ph34r:
10kias for the M20G…
M20C’s kias go up to 11! - Spinal Tap.  :)
MS teaches about diversity… a pair of antennas…. Top and bottom of the fuselage…. One to broadcast to ground stations… the other to the satellite stations…
