Northern Mooniac Posted November 5, 2018 Report Posted November 5, 2018 The pitch servo for my auto pilot failed and needs to be replaced. I got a quote of $3500usd to get it done. Just checking to see whats going on with garmin and Trutrak before I spend this money. I do have an Aspen 1000 Pro right now with all the extras to run the auto pilot as well. 1
KSMooniac Posted November 5, 2018 Report Posted November 5, 2018 Garmin GFC500 should be available for Mooneys very soon...like end of the year. I don't know how well it will integrate with the Aspen but I'd check before spending any money on old king repairs. Sent from my LG-US996 using Tapatalk
aviatoreb Posted November 5, 2018 Report Posted November 5, 2018 I feel your pain. Been there done that. Given the extreme costs of maintaining a KFC200 that tends to want to break periodically at great expense for overhauls - smart money is to replace any broken King product with a new age digital autopilot almost upon us. My hope is my king KFC200 will continue to work nicely for the next few months....so that I can preemptively replace it with the GFC500. If I were in your boat, with a broken KFC200 today, and only maybe 2 months to go - I would hand fly for two months rather than throw good money after bad.
KSMooniac Posted November 5, 2018 Report Posted November 5, 2018 I forgot to plug Bevan Rabell in Wichita...they still do bench repairs on those servos, so you might ask them for a second opinion. Maybe you can get back in business for far less than 3 AMU but I'd still plan for a GFC500.Sent from my LG-US996 using Tapatalk 2
carusoam Posted November 5, 2018 Report Posted November 5, 2018 BK servos are known to wear... OH would be a proper rejuvenation technique... Be sure it is broken and needing replacement in that case... PP thoughts only... Best regards, -a-
Niko182 Posted November 5, 2018 Report Posted November 5, 2018 how could you pair a gfc500 with the Aspen. I always thought the G5 AI was the brain of the whole operation.
KSMooniac Posted November 5, 2018 Report Posted November 5, 2018 The G5 does provide the AHRS input to the GFC500 so you need at least one of them. The Aspen also needs a backup AI, which now can be a G5. What I don't know currently is if the Aspen can connect as an HSI or not. If so, that would be optimal. There wouldn't be a flight director output on the Aspen, though. It would be silly to have an Aspen that can't interface to an autopilot, so if it can't talk to the GFC500 then trading the Aspen for a pair of G5's or a G500 TXi might be up for consideration, but at much higher cost.Sent from my LG-US996 using Tapatalk
N201MKTurbo Posted November 5, 2018 Report Posted November 5, 2018 A fellow Mooney owner (not on Mooneyspace) had a bad trim servo. STEC quoted $3500 to fix it. We troubleshot it and determined the motor was fried. He contacted the motor vendor who said they would do a non-certified overhaul for $250. The servo works perfect now. 1
CaptRJM Posted November 6, 2018 Report Posted November 6, 2018 (edited) I purchased a freshly overhauled KS-270A with paperwork on eBay for $900 about 9 months ago. Looked like new and works perfectly. I'd look around a little before spending $3,500 on an overhaul. We all hope Garmin and Trutrak will have their products available soon ... but, who knows? Have you contacted Alan Fox to see if he has a replacement in stock? Edited November 6, 2018 by CaptRJM spelling
Northern Mooniac Posted November 7, 2018 Author Report Posted November 7, 2018 I seen those on ebay. I could buy a used one to get me buy for the next 6 months and consider my options for an upgrade....
Northern Mooniac Posted November 7, 2018 Author Report Posted November 7, 2018 19 hours ago, CaptRJM said: I purchased a freshly overhauled KS-270A with paperwork on eBay for $900 about 9 months ago. Looked like new and works perfectly. I'd look around a little before spending $3,500 on an overhaul. We all hope Garmin and Trutrak will have their products available soon ... but, who knows? Have you contacted Alan Fox to see if he has a replacement in stock? Who is Alan fox? I checked on ebay and I can't find the exact part number I need unfortunately.
Oldguy Posted November 7, 2018 Report Posted November 7, 2018 56 minutes ago, Northern Mooniac said: Who is Alan fox? I checked on ebay and I can't find the exact part number I need unfortunately. Alan Fox, aka The Grim Reaper, buys and sells used airplane parts and avionics. He has access to a lot of equipment from various model Mooneys and their associated avionics and instruments. I have personally bought several pieces from him and without hesitation will continue to do so. To get in touch with him, throw out an @Alan Fox on MS.
Northern Mooniac Posted November 7, 2018 Author Report Posted November 7, 2018 I sent him a PM, thanks!
CaptRJM Posted November 7, 2018 Report Posted November 7, 2018 Just look on the servo! If you can't get your head in far enough to read the Data Plate then take a picture of it with your phone.
kortopates Posted November 7, 2018 Report Posted November 7, 2018 (edited) 55 minutes ago, CaptRJM said: Just look on the servo! If you can't get your head in far enough to read the Data Plate then take a picture of it with your phone. The p/n is actually on the plug of the servo which is a little closer. You can also look it up in the Mooney IPC. The p/n is specific to our Mooney's which is what makes them rare. Which model AP do you have? Ah, i see KFC-200, sorry I don't know the pitch servo p/n off hand on that one. Edited November 7, 2018 by kortopates
CaptRJM Posted November 7, 2018 Report Posted November 7, 2018 Pitch servo it typically a KS 270 or 270A. The trim servo is a KS 272. Data Plate is on the servo not the connector.
LANCECASPER Posted November 7, 2018 Report Posted November 7, 2018 Might be worth it to give Bob Weber a call. https://www.beechtalk.com/forums/viewtopic.php?f=21&t=152259
CaptRJM Posted November 8, 2018 Report Posted November 8, 2018 My cousin just got a quote to put in a GFC-500 in his PA-28 .... When all was said and done it's just shy of $14 AMU. Not quite the numbers I was expecting.
amillet Posted November 8, 2018 Report Posted November 8, 2018 16 minutes ago, CaptRJM said: My cousin just got a quote to put in a GFC-500 in his PA-28 .... When all was said and done it's just shy of $14 AMU. Not quite the numbers I was expecting. Does that include new servos?
FBCK Posted November 8, 2018 Report Posted November 8, 2018 Northern I had my trim servo overhauled a three years ago by a firm at the Calgary international airport ($800 cdn). Cant remember the name off hand, but it might be worth a few calls. Ive sold the plane since then so I dont have the data. Northern Avionics (Springbank) sent it out for me, they would know.
CaptRJM Posted November 9, 2018 Report Posted November 9, 2018 After checking with him I misquoted the total cost. It’s more like $20K out the door. 2 servos, dual G5’s, GAD 29, and estimated labor to remove the old autopilot and install everything new including interface with his existing 480.
Andy95W Posted November 9, 2018 Report Posted November 9, 2018 9 minutes ago, CaptRJM said: After checking with him I misquoted the total cost. It’s more like $20K out the door. 2 servos, dual G5’s, GAD 29, and estimated labor to remove the old autopilot and install everything new including interface with his existing 480. That's a lot of money, but you get a lot for it, including a very capable, modern autopilot and almost-glass instruments. By comparison, installing an STEC-30 by itself is about $16,000, but without G5s or GPSS- and its 20+ year old technology. 1
