Sounds like a long 1.5mm flat screwdriver may be in order...?
I came across this looking to see what experience can be found..,
https://www.euroga.org/forums/maintenance-avionics/6370-ki-207-indicator-vor-center-adjustment
From there, I got this....
The KI207 doesn’t have any adjustment screws – these are only in the KI203/204.
Have a look at the installation manual:  http://www.seam-avionic.com/pdf/r09eng1yjo.pdf
If you in fact have a KI204, the adjustment screw is a flat blade – about 1.5mm wide will do and don’t push too hard or you’ll bend the legs of the potentiometer. A normal instrument screwdriver is too short so a piece of thin brazing rod filed to a flat blade works fine.
I tried looking for a BK tool, but haven’t turned anything up yet...
best regards,
