I am nearing the end of my 3rd annual and my IA discovered my spinner was previously stop-drilled. He indicated it is an illegal fix and is not airworthy. I took a look at the spinner today and it is apparent that an inept mechanic was at work as the spinner was never cracked. Rather, he stop-drilled a scratch in the paint finish. (SMH).
Since the spinner is not cracked, does the drill hole still result in an unairworthy spinner? If so, what are our replacement options? I have a McCauley 2 blade prop.
Very good question and way over my pay grade.  I’ll be interested in whatever I s the answer.  Good luck, my friend.
Drill an identical hole on the other side... :)
symmetry keeps people from looking any further...
Somebody else asked About replacement spinners in another thread around here earlier...
A few spinners were offered for sale...
If you need a different one see @Alan Fox or @acpartswhse
If you need a different one see [mention=7207]Alan Fox[/mention] or [mention=12721]acpartswhse[/mention]
If I get through without replacement, I will strip the paint as the scratch draws the eye to the drill hole.
If the stop drill hole is 1/8” diameter, put a dead soft rivet in the hole and a dab of paint. Something like an MS20470 A series rivet.
Don’t you have like 12 to 18 stop drilled holes around the circumference of the spinner through which a bunch of screws live?
Spinners ain’t cheap.  Seems like overkill but I’m just an O/O.
My IA reinspected the spinner today and agreed there is no crack therefore no airworthiness issue. I appreciate your thoughts, offers, and input. Crisis averted on this one.
Wow, that's a weird one!
  • 2 weeks later...
Years ago I had a Hartzell spinner with a crack that was stop drilled on one location and another crack that would stop at the screw hole.
I was told it was airworthy with two cracks. IIRC this came from Hartzell and was confirmed by IA and my prop shop during eddy current inspections. I have no idea if that applies to McCauley.
