Can somebody with a Rayjay take a look at their govenor.  I have a a line out of the accessory case on the side to the scavenger pump directly above and then a little closer to the firewall a 45 bend fitting with the line to the prop.  The two lines are parallel right underneath the right mag.
Just trying to verify as having some issues with the govenor after reinstalling the engine.
The line next to the scavenger pump is the oil pressure sense port. There is usually a T put in that line with a line feeding oil to the turbo.
Did you swap the turbo oil line with the prop governor line. If you did, the prop won't work and the turbo is getting way more pressure than it should. Probably won't hurt anything.
