Dream to fly Posted April 25, 2018 Report Share Posted April 25, 2018 I have an idea for a door handle but I am not an engineer and don't want to waste a bunch of time with trial and error but the factory handle SUCKS and after buying two other ones and having the same problem I am thinking outside the box. Can a round rod of say 5/8 or 3/4 diameter be pressed to a thickness of 1/2 inch and still be "solid" or does aluminum degrade in strength as it is formed? Quote Link to comment Share on other sites More sharing options...
Hank Posted April 25, 2018 Report Share Posted April 25, 2018 Aluminum work hardens (bend it ince, it gets stiffer; bend it a second time, stiffer yet; bend it far enough or enough times, it gets so hard it breaks). Any reason it needs to be swaged instead of cut to shape? That's what milling machines are for. Cut the profile, bend to desired weird shape. But I always thought my outside handle was steel . . . The inner handle is definitely aluminum, but wouldn't be made from 1/2" round stock. Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted April 25, 2018 Author Report Share Posted April 25, 2018 2 minutes ago, Hank said: Aluminum work hardens (bend it ince, it gets stiffer; bend it a second time, stiffer yet; bend it far enough or enough times, it gets so hard it breaks). Any reason it needs to be swaged instead of cut to shape? That's what milling machines are for. Cut the profile, bend to desired weird shape. But I always thought my outside handle was steel . . . The inner handle is definitely aluminum, but wouldn't be made from 1/2" round stock. Its the inside handle it is cast. I would like to make a nice machined handle that is a simple build. (I'm guessing here) but 1 in round stock that is drilled and pinned to fit the door release rod then a flattened rod that is curved and tig welded to that to form the handle simple easy and looks good Quote Link to comment Share on other sites More sharing options...
Hank Posted April 25, 2018 Report Share Posted April 25, 2018 In my own limited welding experience, aluminum ain't exactly easy to weld (at least to weld nicely). It will still need machining to clean things up, somwhy not just start with bar stock (1" x 2") and machine it all? Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted April 25, 2018 Author Report Share Posted April 25, 2018 In my own limited welding experience, aluminum ain't exactly easy to weld (at least to weld nicely). It will still need machining to clean things up, somwhy not just start with bar stock (1" x 2") and machine it all? Don't have a mill. But I have a tig machineSent from my E6810 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Hank Posted April 25, 2018 Report Share Posted April 25, 2018 Weld away! I have a small mill at home, and fancy ones at work . . . . . Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted April 25, 2018 Author Report Share Posted April 25, 2018 Weld away! I have a small mill at home, and fancy ones at work . . . . . I was trying to be on the cheap side. It's a handle not a landing struts. But I see your point. Sent from my E6810 using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 25, 2018 Report Share Posted April 25, 2018 In the design stage... consider things like bumping into it in turbulence ... or getting caught on it while entering or exiting the plane... that kind of thing... Insulating it for winter operations... My M20C handle for a while was a steel Allen key... doubled as a radio remover.... Replacing the door plastic took longer than expected. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
RLCarter Posted April 25, 2018 Report Share Posted April 25, 2018 Making a handle would be time consuming with hand tools, 5-axis CNC would make it easier but a lot of waste, honestly cast is the way to go (pour and drill 2 holes). Quote Link to comment Share on other sites More sharing options...
Hank Posted April 25, 2018 Report Share Posted April 25, 2018 34 minutes ago, RLCarter said: Making a handle would be time consuming with hand tools, 5-axis CNC would make it easier but a lot of waste, honestly cast is the way to go (pour and drill 2 holes). Few people have mills at home. Even fewer have the ability to melt aluminum for casting (>1200°F). Quote Link to comment Share on other sites More sharing options...
RLCarter Posted April 25, 2018 Report Share Posted April 25, 2018 12 minutes ago, Hank said: Few people have mills at home. Even fewer have the ability to melt aluminum for casting (>1200°F). True but a small foundry can be cobbled together for less than 100 bucks Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted April 25, 2018 Report Share Posted April 25, 2018 I thought everybody had a mill and a lathe. 4 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted April 25, 2018 Report Share Posted April 25, 2018 13 minutes ago, DonMuncy said: I thought everybody had a mill and a lathe. Right?..... Well my CNC mill is in a buddies man cave but I have a clicker to get to it when I need to Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted April 25, 2018 Report Share Posted April 25, 2018 1 minute ago, RLCarter said: Right?..... Well my CNC mill is in a buddies man cave but I have a clicker to get to it when I need to Smart aleck. Mine is not CNC. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted April 25, 2018 Report Share Posted April 25, 2018 7 minutes ago, DonMuncy said: Smart aleck. Mine is not CNC. lol, 80% of the time it's quicker to use it manually. Oh, it doesn't have a tool changer Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted April 25, 2018 Report Share Posted April 25, 2018 What is wrong with the factory handle? On my old F the plastic was falling off, so I took all the plastic off and polished the handle. It looked great. I replaced the roll pin with a clevis pin and cotter pin like on the trim tubes and it never gave me any more trouble. Quote Link to comment Share on other sites More sharing options...
yvesg Posted April 25, 2018 Report Share Posted April 25, 2018 6 hours ago, David Herman said: Service Instruction M20-39 http://www.mooney.com/en/si/M20-39.pdf Anyone knows how much is that kit? Yves Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted April 25, 2018 Author Report Share Posted April 25, 2018 What is wrong with the factory handle? On my old F the plastic was falling off, so I took all the plastic off and polished the handle. It looked great. I replaced the roll pin with a clevis pin and cotter pin like on the trim tubes and it never gave me any more trouble. The casting crackedSent from my E6810 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted April 25, 2018 Report Share Posted April 25, 2018 7 hours ago, DonMuncy said: I thought everybody had a mill and a lathe. If you own a 40 year old plane and don't have these tools you are hurting yourself. Don't forget at least 2 different types of electric welders and a gas rig as well. I spent half a day a few years ago making a part for something that I could have went out and bought the entire thing I was fixing new for less money than the cost of my time but it was the principle of it. I have been using my mill and lathe a lot lately for non aviation projects. Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted April 25, 2018 Report Share Posted April 25, 2018 1 minute ago, Dream to fly said: The casting cracked Sent from my E6810 using Tapatalk so do you really want to make a new one (better mouse trap) or be happy with a replacement and move on? I'm sure there are plenty of originals to be had for cheap. Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted April 25, 2018 Author Report Share Posted April 25, 2018 If you own a 40 year old plane and don't have these tools you are hurting yourself. Don't forget at least 2 different types of electric welders and a gas rig as well. I spent half a day a few years ago making a part for something that I could have went out and bought the entire thing I was fixing new for less money than the cost of my time but it was the principle of it. I have been using my mill and lathe a lot lately for non aviation projects. I think you guys are going to get me in trouble. I've been trying to buy a combo unit for a while but the plane keeps dipping into that fund. Might have to dip into the wife's vacation fund and say the other pilots made me do it. Thats gotta flySent from my E6810 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted April 25, 2018 Author Report Share Posted April 25, 2018 so do you really want to make a new one (better mouse trap) or be happy with a replacement and move on? I'm sure there are plenty of originals to be had for cheap. The right answer is probably buy another one and move one. The better answer is prove a better design get more "needed" tools and go nuts.Sent from my E6810 using Tapatalk Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted April 25, 2018 Report Share Posted April 25, 2018 CB way to cast aluminum. Get an insulating fire brick and carve a void the shape of the part you need. Turn your TIG machine up high. Hook the ground to a heavy aluminum bar, start the arc and feed the molten aluminum into the void. Let it cool, bust it out, sand, drill, machine to fit. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted April 25, 2018 Report Share Posted April 25, 2018 The interior handle on mine was like most, the plastic coating was in bad shape. A serviceable unit spendy if memory serves so i stripped the plastic, inspected the casting around the mounting boss then wrapped it in leather. The hole in door plastic looked like crap so that was straightened up and I turned an escutcheon out of Delrin with an o-ring grove then split it, the two halve are held together with the o-ring and hides and keeps the roll pin from coming out Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted April 25, 2018 Report Share Posted April 25, 2018 4 hours ago, 1964-M20E said: If you own a 40 year old plane and don't have these tools you are hurting yourself. Don't forget at least 2 different types of electric welders and a gas rig as well. I spent half a day a few years ago making a part for something that I could have went out and bought the entire thing I was fixing new for less money than the cost of my time but it was the principle of it. I have been using my mill and lathe a lot lately for non aviation projects. I have a gas rig. and an old arc unit. I am contemplating a new cheap wire welder. Almost all my projects are not economically practical. But since my time is worth about 10 cents and hour now, I figure it is OK. 1 1 Quote Link to comment Share on other sites More sharing options...
