I am looking for a Ground Power Unit (GPU) to allow running of avionics, updating software, etc... without running engine.  I have a Battery Minder, but that does not supply enough power.  I am thinking 25 - 50 amps of clean power.  The aviation ones run about $600.00.  There is an automobile company that makes an aviation product (available from Spruce) for about $250.00.  Are there other sources of power supplies that can do the job, but do not have the "aviation" word attached to them that raises the price to 1/2 AMU?
John Breda
You can buy the power plug from McMaster.   A couple or one 12Volt auto batteries and a car 12 volt charger should get you going.
I have one of these in my shack...it doesn't do 24 v though so I found a 24 v witching power supply on amazon for 90 bucks...puts out max 17 amps which is more than enough
The trucking industry often uses 24V systems...
The local starting cart has a bunch of deep cycle batteries in it.  Wired specifically for 12V and 24V applications...
PP Thoughts that come to mind....
My airplane is a 12 volt system so that makes it easier.
I do not understand the three wire plug going into the airplane.  Pos and Neg DC is obvious.  However, the plug has three wires.  I understand that the third wire somehow activates a solenoid at the battery so the GPU has access to the bus.  Do I have that right?
The Alinco units look reasonable, but I am not sure I like an adjustable voltage as it give rise to the possibility of error.
The IOTA DLS-45 has 45 amp, and converts 108-132 AC to 13.4 DC.  It will charge and automatically drop to float charge.  It would be more than enough to do what I want.
This unit from Spruce http://www.aircraftspruce.com/pages/el/powersupply/portPowerCharger.php  apparently will run the avionics well, but if you want to do anything with audio while on the ground, it inject lots of interference so is not goof for that.
I assume the Alinco units, which are marketed towards the ham radio users, would be better with powering audio and providing clean and controlled current.
Then there is the unknown for me, if I used a unit like the Alinco or IOTA, how is the third pin wired?
Can someone who knows more about this than me chime in?
John Breda
Third (smaller) pin is +
I bought a used DIN rail 28V 20 amp power supply off eBay for ~ $30.
 Then I got 20' of 8 gauge flexible wire and the standard plug from Aircraft Spruce to mate with the airplane.
Works ok to run G500 GTN750 etc to upgrade firmware.
Edited by Jerry 5TJ
The third pin provides voltage for a solenoid that is on top of the battery box.  The  solinoid activates the power plug.   It is a way to keep the plug from being "live" when the plug is not covering the pins.....
John Breda
John, the 3rd pin in the external  power socket does energize a solenoid that closes the circuit of the positive pin to the battery. I use a charger to run avionic and charge the battery if needed. Some charger has a smart feature that prevents the charger from energizing unless it sees a battery which is a catch 22 since the battery is not in the circuit until the 3rd pin sees 12V.
John Breda
There is a switch on the back that disables the adjustment knob on the front and uses a default preset value which you can change. The switch is recessed so it is unlikely to get flipped, but could be covered by some rtv. I have never noticed these causing noise. They spec the ripple at 15mv at full load I believe.  The lighter plug on the front is also nice for powering stuff at home that you would normally have to take out to the car
Edited by N601RX
I have this one from Sears for the last ten years, I think it was about $90. On the maximum amp setting it can delivers 10 amp at 28volts or 200 amps at 14 volts It has wheels for moving it around. Very handy for avionics testing.
José
I thought and was told these three prong plug where only for starting the engine, when the battery was dead, and would not power the avionics, is this not correct, I can power the plane?
No they have specific units to power the avionics via the plug, mine was just under $400 and I used it quite a bit when learning the g1000
The people telling you were not correct.
  • 1 month later...
Yetti - do you have a link for the McMaster plug - can't seem to find it.  Thanks -Brad
Some reason I can't find it either.  Checked Grainger also.   I recall getting the part number off the plug on the plane and looking it up.  Spruce had them under Cessna connector...
