Cruiser Posted July 12, 2017 Report Posted July 12, 2017 31 minutes ago, flyntgr1 said: Is this upgrade only for the pro or will it work on the VFR version? Not available on the PFD Pilot or VFR PFD Quote
Marauder Posted July 12, 2017 Report Posted July 12, 2017 The PFD display options for ESV are: Full Screen, Split Screen with the standard Nav Display, or Split Screen with the Nav Display overlaying the Topographical Map When a PFD or EBD or MFD has the Synthetic Vision (ESV) option enabled it is required that a Sonalert be connected to the PFD unless TAWS is installed Thanks for the explanation Tom. I take it that TAWS is an extra package that is not included in the promotion they are running now for existing owners. I have the MV-17 from EI installed, so that will take care of the Sonalert requirement. Sent from my iPad using Tapatalk Pro Quote
flyntgr1 Posted July 12, 2017 Report Posted July 12, 2017 9 hours ago, Cruiser said: Not available on the PFD Pilot or VFR PFD Thanks. My brother has the VFR PFD in his Swift, but doesn't want to spend the 6k for the upgrade to pro as he does not fly ifr in it. 1.5k for this upgrade sounds like a smoking deal! Quote
mike_elliott Posted July 12, 2017 Report Posted July 12, 2017 21 hours ago, teejayevans said: Does it show traffic in the SV mode? yes, traffic is cool in the sv mode 1 Quote
Mooney in Oz Posted July 13, 2017 Report Posted July 13, 2017 On 12/07/2017 at 1:53 AM, teejayevans said: Does it show traffic in the SV mode? About the 50 second mark for about 2 secs: 1 Quote
