Drumstick Posted May 27, 2017 Report Posted May 27, 2017 Can anyone give me a aircraft spruce parts number for the 1/8 and 1/16" engine shims for an M20C?
RLCarter Posted May 27, 2017 Report Posted May 27, 2017 Don Maxwell article HERE 600364-001 is one-sixteenth 600364-003 is one-eighth 1
RLCarter Posted May 27, 2017 Report Posted May 27, 2017 8 minutes ago, carusoam said: Perfect response, RLC! Best regards, -a- Sort of.....these are Mooney #'s not Spruces, but Don can hook him up
Drumstick Posted May 28, 2017 Author Report Posted May 28, 2017 3 hours ago, RLCarter said: Sort of.....these are Mooney #'s not Spruces, but Don can hook him up I was hoping to place an order from just one vendor. I was getting the mounts from spruce hence my request for info, I'll call Don.
RLCarter Posted May 28, 2017 Report Posted May 28, 2017 1 hour ago, Drumstick said: I was hoping to place an order from just one vendor. I was getting the mounts from spruce hence my request for info, I'll call Don. I looked but couldn't find anything from Spruce, call Don, he might be able to tell you the # if Spruce carries them. It's my understanding that it is a large area washer, and you cut a slot for ease of installation, if you had all the dementions you might be able find the "AN" or "MS" number and get them that way
Guest Posted May 28, 2017 Report Posted May 28, 2017 The thicker ones are supplied with every new Lord mount set, your shop may have a few spares. The thin ones can be made with a hole saw and a piece of 1/16" 4130 sheet. Clarence
Drumstick Posted May 28, 2017 Author Report Posted May 28, 2017 1 hour ago, M20Doc said: The thicker ones are supplied with every new Lord mount set, your shop may have a few spares. The thin ones can be made with a hole saw and a piece of 1/16" 4130 sheet. Clarence Thanks!
Drumstick Posted July 14, 2017 Author Report Posted July 14, 2017 On 5/28/2017 at 7:05 AM, M20Doc said: The thicker ones are supplied with every new Lord mount set, your shop may have a few spares. The thin ones can be made with a hole saw and a piece of 1/16" 4130 sheet. Clarence Just FYI - my new lord mounts did not come with shims.
Hudson W Posted February 5, 2022 Report Posted February 5, 2022 On 5/27/2017 at 3:48 PM, RLCarter said: Don Maxwell article HERE 600364-001 is one-sixteenth 600364-003 is one-eighth Does anyone have this Don Maxwell article archived offline? It looks like he removed it from his site. What is the diameter measurement of both of those shims? 600364-001 and 600364-003 Are there any other alternative part numbers? LASER gouges $100 each and that price adds up after you need 8 of them.
Bartman Posted February 5, 2022 Report Posted February 5, 2022 Do you have a pilot friend who or your A+P who recently changed mounts? I suggest finding some that were removed and use them. Ask around at your airport, shouldn’t be too hard to find.
EricJ Posted February 5, 2022 Report Posted February 5, 2022 15 hours ago, Hudson W said: Does anyone have this Don Maxwell article archived offline? It looks like he removed it from his site. What is the diameter measurement of both of those shims? 600364-001 and 600364-003 Are there any other alternative part numbers? LASER gouges $100 each and that price adds up after you need 8 of them. It's on the wayback machine. The pics are missing, but if you're familiar with the mounts and shims they don't add that much. https://web.archive.org/web/20190207032717/http://donmaxwell.com/aligning-your-engine-using-shims/ 1
David Lloyd Posted February 5, 2022 Report Posted February 5, 2022 Back in my experimental days, AN970 washers from Spruce did the job. One washer on each bottom mount will raise the spinner about 3/8”. Not me, but have seen the same use on a Mooney after cutting a slot to ease installation. 2
N201MKTurbo Posted February 5, 2022 Report Posted February 5, 2022 (edited) After almost 40 years of Mooney ownership, I have a whole box of those motor mount washers. I even have one that I’m pretty sure was modified by DMax himself. I have quite a few of his signatures in my logbooks before I bought it. Edited February 5, 2022 by N201MKTurbo 1
Fly Boomer Posted February 5, 2022 Report Posted February 5, 2022 This article from DMAX is still not great, but it has some pics. 2001-06 MAPA Log 24.06 Aligning Your Engine.pdf 1
Guest Posted February 6, 2022 Report Posted February 6, 2022 21 hours ago, Hudson W said: Does anyone have this Don Maxwell article archived offline? It looks like he removed it from his site. What is the diameter measurement of both of those shims? 600364-001 and 600364-003 Are there any other alternative part numbers? LASER gouges $100 each and that price adds up after you need 8 of them. Same diameter as standard Lord mount shim washers, I’d have to measure one to get the exact measurement. As a general rule of thumb, the lift at the spinner is four times the washer thickness. At $100 each I’d buy a holes saw and a piece of 4130 steel from Spruce if your maintainer doesn’t have some. Clarence
EricJ Posted February 6, 2022 Report Posted February 6, 2022 5 minutes ago, M20Doc said: At $100 each I’d buy a holes saw and a piece of 4130 steel from Spruce if your maintainer doesn’t have some. Buy a punch and make a bunch and retire! https://www.harborfreight.com/hydraulic-punch-driver-kit-96718.html
