Yes.  If there are new posts that you haven't seen, it'll say new "jump to new" next to the thread title.  You'll have to be logged in and go to each forum to see it though.
Or you can click on the "View New Posts" link , but I don't use that feature all that often.
Brian
to mark the post read.....
after getting the list of messages as Brian says above, put a check mark in the box to the left of each message or to select all, check mark the Forum box at the top,  and then click on delete at the bottom. Note: this does not delete the message, it marks the message (post) as read and it will not appear again in the list of new messages the next time you check. You can always go to the forum and see all messages there.
  • 1 month later...
This must be a Windows-only thing, as I see neither check boxes nor delete buttons anywhere on the screen using my Mac, with either Safari or FireFox. Interesting.
  • 3 weeks later...
