LANCECASPER Posted January 25 Report Posted January 25 11 hours ago, outermarker said: Bushings can’t be bought in the correct length? This should work and you save shipping by buying both at the same time. Grangier p/n 3ZM99 Probably wouldn't even need to be brass. For $1 each, this should work: https://www.amazon.com/Aluminum-Lengths-Metal-Spacers-Online/dp/B07V8F6KPT/ref=sr_1_16?crid=2M1DWS7VNRTAA&keywords=hillman+bronze+bushing+1%2F4+x+3%2F8+x+1%2F2&qid=1706188304&sprefix=hillman+bronze+bushing+1%2F4+x+3%2F8+x+1%2F2%2Caps%2C95&sr=8-16 1 Quote
Echo Posted January 25 Report Posted January 25 13 hours ago, outermarker said: Bushings can’t be bought in the correct length? This should work and you save shipping by buying both at the same time. Grangier p/n 3ZM99 My vote for best edit of the year. Thanks. I ordered these and will be sending back the home depot (sawing project) bushings. Scott 1 Quote
Echo Posted January 25 Report Posted January 25 1 hour ago, LANCECASPER said: Probably wouldn't even need to be brass. For $1 each, this should work: https://www.amazon.com/Aluminum-Lengths-Metal-Spacers-Online/dp/B07V8F6KPT/ref=sr_1_16?crid=2M1DWS7VNRTAA&keywords=hillman+bronze+bushing+1%2F4+x+3%2F8+x+1%2F2&qid=1706188304&sprefix=hillman+bronze+bushing+1%2F4+x+3%2F8+x+1%2F2%2Caps%2C95&sr=8-16 Nice! 1 Quote
0TreeLemur Posted January 25 Report Posted January 25 Maybe an ignorant question. I searched through this thread and it doesn't seem to have been discussed. What log book entry is required if owner produced seat rollers are installed? Is that something that requires an A&P sign off? Quote
EricJ Posted January 25 Report Posted January 25 31 minutes ago, 0TreeLemur said: Maybe an ignorant question. I searched through this thread and it doesn't seem to have been discussed. What log book entry is required if owner produced seat rollers are installed? Is that something that requires an A&P sign off? Any OPP part requires documentation from the producer (e.g., you) commemorating the production, and then a record from the installer indicating that it is suitable for installation and correctly installed. Whether a seat roller falls under Preventive Maintenance and can be installed by the owner is kind of grey since the FAA says the list of PM tasks in the regs is "not comprehensive". My usual advice is that if your IA is good with it then there should be no issue. 1 Quote
Bob E Posted January 26 Report Posted January 26 Yeah, when I reupholstered my seats with the Airtex set, that's when I also replaced the rollers. My AI entered the Airtex seats and really liked the nylon rollers but didn't see a need to mention them. 2 Quote
Ragsf15e Posted January 26 Report Posted January 26 Installed the ones from Lasar today. Super easy swap and it rolls much better! 3 Quote
outermarker Posted January 28 Report Posted January 28 Hopefully, this helps complete this thread, it’s been a good one. I received the spacers and felt the slop was too much for me. So, I placed an index mark on the edge of the spacer where the tape began and found out that 3 revolutions of 3M Super33 black tape (used also for the Britain servos) created a very snug fit. I inserted the spacer by twisting the spacer into the roller and then trimmed off the excess tape. I haven’t installed the rollers yet but look forward to the improvement. 3 Quote
Echo Posted February 11 Report Posted February 11 Talk about a stark difference between new and OEM with 59 years of service. 1 Quote
Meshach Posted August 18 Report Posted August 18 On 1/28/2024 at 4:18 PM, outermarker said: Hopefully, this helps complete this thread, it’s been a good one. I received the spacers and felt the slop was too much for me. So, I placed an index mark on the edge of the spacer where the tape began and found out that 3 revolutions of 3M Super33 black tape (used also for the Britain servos) created a very snug fit. I inserted the spacer by twisting the spacer into the roller and then trimmed off the excess tape. I haven’t installed the rollers yet but look forward to the improvement. PIREP? @outermarker Quote
Ragsf15e Posted August 18 Report Posted August 18 27 minutes ago, Meshach said: PIREP? @outermarker Lasar shows the real ones in stock now. Fit right out of the package. https://lasar.com/interior-hardware/seat-roller-140004-000 Quote
outermarker Posted August 19 Report Posted August 19 It's too soon to know the longevity of the rollers I installed. The tracks are clean and the seats roll with ease. I like the idea of a metal bushing making contact with the bolt vs. just the molded part but it might not matter because how often are the seats being moved up and down the tracks? I would think the weight of the person in the seat impacts the roller's longevity most. Quote
