Browncbr1 Posted March 15, 2017 Report Posted March 15, 2017 Does the GTN 650 have an integrated audio panel/intercom, etc? Or is it just simply a remote control feature that requires an actual audio panel box to also be installed??
Raptor05121 Posted March 15, 2017 Report Posted March 15, 2017 I have not used one yet, but I'm pretty sure the 650 is simply a COM/NAV radio and GPS unit. It still needs to be hooked into a audio panel to select different radio heads, etc (Garmin 340, etc) 1
PTK Posted March 15, 2017 Report Posted March 15, 2017 19 minutes ago, Browncbr1 said: Does the GTN 650 have an integrated audio panel/intercom, etc? Or is it just simply a remote control feature that requires an actual audio panel box to also be installed?? The GTN650 can control a remote transponder but not remote audio panel. GTN750 can control both. The remote units are separate boxes. 1
Vance Harral Posted March 15, 2017 Report Posted March 15, 2017 No integrated audio panel, but it does have a feature that allows you to monitor audio on the standby frequency. This is almost like having an additional listen-only COM radio. I use the feature to start monitoring tower/CTAF early when I'm still talking to approach, or to monitor radio traffic when I'm halfway between two closely-spaced airports. 1
Browncbr1 Posted March 15, 2017 Author Report Posted March 15, 2017 Thanks guys.. After playing with the ipad sim for the GTN and IFD, I feel like the GTN is just way more intuitive, but as you know, the simulator is a GTN 750, not 650, so I was trying to understand some of the differences... I understand that the GTN650 will also cross feed with my Aera510 2
PTK Posted March 15, 2017 Report Posted March 15, 2017 15 minutes ago, Browncbr1 said: Thanks guys.. After playing with the ipad sim for the GTN and IFD, I feel like the GTN is just way more intuitive, but as you know, the simulator is a GTN 750, not 650, so I was trying to understand some of the differences... I understand that the GTN650 will also cross feed with my Aera510 You can also play with the 650 simulator. Go to settings in the ipad and go to Garmin GTN. Change from 750 to 650. 1
bradp Posted March 15, 2017 Report Posted March 15, 2017 I'm the opposite- after playing with both simulators I found the IFD to be more intuitive for how my brain works. But in the end they're both great. Just a little different. Sent from my iPhone using Tapatalk
DAVIDWH Posted March 16, 2017 Report Posted March 16, 2017 Vance, "No integrated audio panel, but it does have a feature that allows you to monitor audio on the standby frequency" How is that done?
DAVIDWH Posted March 16, 2017 Report Posted March 16, 2017 No worries mate, just found the monitor function key. 1
