StevenL757 Posted February 21, 2017 Report Posted February 21, 2017 Has any Ovation, Eagle, Acclaim, or Bravo owner replaced their forward windscreen, and if so, who did you use? Would you recommend anyone different if you had to do it again? I have a small vertical crack nearly an inch long, slightly left of CL, starting at the top edge where the windscreen meets the aircraft skin. As the crack has gradually grown over the last 6 months, I'm starting to line up prospective sources in case it doesn't pass annual this year. Spoke with my IA today, and although he can do the work, he admits it isn't his strongest area and would feel comfortable if someone else with this expertise engage. Grateful for any thoughts, as I've heard horror stories and am dreading the thought of having to eventually do this. Thanks all... Steve Quote
LANCECASPER Posted February 21, 2017 Report Posted February 21, 2017 That might be a Don Maxwell job. 1 Quote
carusoam Posted February 21, 2017 Report Posted February 21, 2017 I would expect Dave at the MSC in NJ has the experience. The acrylic plastic will continue to crack unless stop drilled. it is probably better to stop drill it and fill the drilled hole with silicone until until you can get the window replaced. The crack can continue in one direction or do a whole bunch of random changes of direction. There is a lot of air pressure on the windscreen generating the force needed to propagate the crack... Best regards, -a- 1 Quote
jetdriven Posted February 21, 2017 Report Posted February 21, 2017 (edited) The windscreen is not very hard to replace...very carefully drill all 60 rivets off the lower retainer of that windshield,clean out the channel apply new PRC, reinstall the retainer strip with number 4 cherrymax rivets. I've seen some really really really poor jobs of replacing the windshield with Phillips head screws and stuff like that holding he retainer on. It should be indistinguishable from factory if done right. Also spend the extra bucks and get the UV silver gray tint it looks really nice Edited February 21, 2017 by jetdriven 1 Quote
Rmag Posted February 21, 2017 Report Posted February 21, 2017 (edited) Steven: I own a repair station at KMQS in PA. http://www.sureflight.com 136 nm from KISP. We bought a Mooney 205 that we are refurbishing: paint, interior, and avionics. We changed all the windows including the windshield with a Great Lakes Areo .250" extra thick windshield. We can replace your windshield and professionally repaint the lower retainer after it is riveted back on. Feel free to email me at dwatkins@sureflight.com me if you are interested. Here is a few photos from our install last month. Edited February 21, 2017 by Rmag 1 Quote
ArtVandelay Posted February 21, 2017 Report Posted February 21, 2017 The windscreen is not very hard to replace...very carefully drill all 60 rivets off the lower retainer of that windshield,clean out the channel apply new PRC, reinstall the retainer strip with number 4 cherrymax rivets. BUT if it's already been replaced at one time then those 60 rivets are cherries? Quote
jetdriven Posted February 21, 2017 Report Posted February 21, 2017 (edited) Usually, that is the case. If not, then its significantly more work to remove the cherry rivets. I think someone sells a tool for this, but a dremel with a very small bit on the end will work. Grind into the flat end of the rivet until you destroy the lock ring, then drive out stem. You can also grind off the back side of the rivet, most can be reached. Edited February 21, 2017 by jetdriven Quote
Rmag Posted February 21, 2017 Report Posted February 21, 2017 Took a few shots today of the windows completed and a close up of the windshield rivets painted. 2 Quote
LANCECASPER Posted February 21, 2017 Report Posted February 21, 2017 Wow nice job. That's going to be a beautiful J. Quote
Rmag Posted February 21, 2017 Report Posted February 21, 2017 Thanks when it's complete I'll post pics of everything in a separate thread. 1 Quote
Marauder Posted February 21, 2017 Report Posted February 21, 2017 Thanks when it's complete I'll post pics of everything in a separate thread. Say hello to Chris from me. He installed my Aspens, GTN among other things. Sent from my iPad using Tapatalk Pro Quote
Rmag Posted February 21, 2017 Report Posted February 21, 2017 Will do, will he know who "Marauder" is? If you check out the first picture in the Avionics Gallery on our website, you will see his handiwork on our Mooney. Quote
StevenL757 Posted February 22, 2017 Author Report Posted February 22, 2017 Thanks all for the direction, and to Dan at Sureflight for the offer. I'll consider these options and make a few calls. Quote
carusoam Posted February 22, 2017 Report Posted February 22, 2017 I quickly reviewed some photos at the SureFlight web site... There are some pretty extravagant paint and interiors done there. One photo in particular showed a comfy chair and chess set on a table. Playing chess in the backseat of a Mooney could be pretty interesting. The table would need some strong magnets to hold everything in place. Best regards, -a- Quote
Rmag Posted February 22, 2017 Report Posted February 22, 2017 (edited) Your welcome Steve. And carusoam, yep, no chess in the Mooney! If it's a must, best to use an iPad!!! And marauder, Chris knows you and said "hi". Edited February 22, 2017 by Rmag 1 Quote
flyboy0681 Posted February 22, 2017 Report Posted February 22, 2017 19 hours ago, Rmag said: Will do, will he know who "Marauder" is? If you check out the first picture in the Avionics Gallery on our website, you will see his handiwork on our Mooney. The panel itself looks great, but painting the sheet metal black makes it look dated. One of my next projects is to have my panel powder coated a light color. Quote
Rmag Posted February 22, 2017 Report Posted February 22, 2017 It's not black. It just shows up darker in the photo contrasting with the lit screens it's a grey that matches the seat leather. Quote
LANCECASPER Posted February 22, 2017 Report Posted February 22, 2017 On 2/20/2017 at 10:14 PM, LANCECASPER said: That might be a Don Maxwell job. Well . . . after further consideration . . . looking after Sureflight's work on the Mooney 205 and their website and since it's 136 nm away, it definitely looks like they have the expertise to do it. It's nice to have options but it's nice to have the work semi-local. Quote
