carusoam Posted December 20, 2016 Report Posted December 20, 2016 Propane would be nice. It evaporates slower at cold temps, but still works pretty well in my grill. A propane spill can still be dangerous, but it won't leave a big blue stain behind on the rug. finding propane while on the road may have some drawbacks... Best regards, -a-
tigers2007 Posted December 20, 2016 Author Report Posted December 20, 2016 Could it run for a few hours off a single one-pounder?Sent from my iPhone using Tapatalk
carusoam Posted December 20, 2016 Report Posted December 20, 2016 Pound for pound the fuels have a very similar heat output. A pound is 1/6th of a gallon. It probably won't last that long. Check with the manufacturer to get the details of FF from them... Best regards, -a-
peevee Posted December 20, 2016 Report Posted December 20, 2016 1 hour ago, carusoam said: PV, check my above post to see if it explains your observation... Best regards, -a- makes sense, I always assumed it was the higher octane and resulting detonation resistance or something. Thanks. 1
peevee Posted December 20, 2016 Report Posted December 20, 2016 51 minutes ago, carusoam said: Propane would be nice. It evaporates slower at cold temps, but still works pretty well in my grill. A propane spill can still be dangerous, but it won't leave a big blue stain behind on the rug. finding propane while on the road may have some drawbacks... Best regards, -a- propane works great in the cold. Companies make propane fired ice augers for fishing and they work very, very well.
aviatoreb Posted December 20, 2016 Report Posted December 20, 2016 1 hour ago, carusoam said: Erik, the 100LL is a concern because it doesn't evaporate very well as the temperature descends. There is a temperature that the rate of evaporation slows to a less than useable rate. Heating the intake of the lawn tractor is used so the fuel vaporizes. There is a nice choke on the engine that really helps to keep it running once it starts. Preheat for the tractor usually involves a torch on that one spot. Make sure it is metal. Some intakes have becom plastic tubes... Briefly, pre-heat is for a few reasons... - increases tight spaces that can occur with tight tolerances. - increases oil flow for protection of expensive to OH engines. - evaporates fuel for ignition. the preheat for 100LL shows up as the temps go below 20°F. Continental cold start Advice is interesting. They say cold starts can occur below 20°F without pre-heat, IIRC..? Bummer, Nobody cares for that poor lonely lawn tug.... Best regards, -a- I don't know what it is supposed to do, but really in my tug anyway, 100LL seems to work just fine in a possible temps without a hitch, including easy starting at -10F. 1
peevee Posted December 20, 2016 Report Posted December 20, 2016 17 minutes ago, tigers2007 said: Could it run for a few hours off a single one-pounder? Sent from my iPhone using Tapatalk I'd guess 72 minutes, here's why. People run the honda eu2000 off propane and say it'll run 24 hours on a 20lb bottle, 1/20th of 24 hours is 72 minutes 2
peevee Posted December 20, 2016 Report Posted December 20, 2016 (edited) So, side question, how safe are those one pounders at altitude? I have left them behind before because I wasn't sure. I saw some posts on back country pilot that indicated they were OK but those guys aren't in the flight levels. I have found them at just about every grocery store or Walmart I have been to, but they're expensive. Maybe it's not worth it. Edited December 20, 2016 by peevee
carusoam Posted December 20, 2016 Report Posted December 20, 2016 Look to see if they have what looks like a Schraeder valve built in on them, so it is possible that they can relieve pressure before exceeding the strength of the bottle itself. it is pretty easy to build in the safety of one extra atmosphere of pressure. So removing the outside pressure of one atmosphere shouldn't cause it any harm... the environment that campers use going up into the mountains is pretty typical of our flight altitudes... This is logic of a PP, not an expert in propane tanks.... Best regards, -a-
peevee Posted December 20, 2016 Report Posted December 20, 2016 55 minutes ago, carusoam said: Look to see if they have what looks like a Schraeder valve built in on them, so it is possible that they can relieve pressure before exceeding the strength of the bottle itself. it is pretty easy to build in the safety of one extra atmosphere of pressure. So removing the outside pressure of one atmosphere shouldn't cause it any harm... the environment that campers use going up into the mountains is pretty typical of our flight altitudes... This is logic of a PP, not an expert in propane tanks.... Best regards, -a- Yeah, they do. However I'm not sure I'd feel too great about one relieving itself in the back of the plane either. I guess we're pretty drafty so it might not matter.
DonMuncy Posted December 20, 2016 Report Posted December 20, 2016 I keep starting fluid around to avoid hard starting on "pull to start" engines. I have a 15 HP chipper shredder which is tough enough to pull, my 78 year old pulling mechanism can only make one pull. The starting fluid starts it every time on that one pull. 1
Marauder Posted December 22, 2016 Report Posted December 22, 2016 Mine is showing up today. Hopefully the "honey do" list doesn't get in the way and I can give a PIREP on the unit. I have a watt meter I can put inline to see when it craps out. Quiet! Here comes honey!Sent from my iPad using Tapatalk 1
TWinter Posted December 22, 2016 Report Posted December 22, 2016 Couldn't resist the price. Ordered a few days ago and received yesterday. Have not had a chance to fire it up, but I do like the size. Time will tell. I'm a sucker for a discount deal. -Tom
MCDsiena Posted December 22, 2016 Report Posted December 22, 2016 I ordered one as well and should be delivered tomorrow. I will have time to play with it and give some feedback. I think Sportsman Generator company owes Tigers2007 some commission on the orders he generated.
tigers2007 Posted December 22, 2016 Author Report Posted December 22, 2016 Troll eBay for cheap new-old-stock Hobbs meters. I paid like $9 shipped. Came in a box from the 60's. I fired up the generator yesterday and had it running the 200w Reiff + 250w Honeywell cabin heater and I could tell from the engine sound that it was working. Wasn't struggling though; just a deeper tone. Do not forget to move the choke lever back to normal or else the engine will bog down. I used synthetic 5W-30 as it's theoretically going to be used outdoors in below freezing temps. Sent from my iPhone using Tapatalk
Marauder Posted December 23, 2016 Report Posted December 23, 2016 Troll eBay for cheap new-old-stock Hobbs meters. I paid like $9 shipped. Came in a box from the 60's. I fired up the generator yesterday and had it running the 200w Reiff + 250w Honeywell cabin heater and I could tell from the engine sound that it was working. Wasn't struggling though; just a deeper tone. Do not forget to move the choke lever back to normal or else the engine will bog down. I used synthetic 5W-30 as it's theoretically going to be used outdoors in below freezing temps. Sent from my iPhone using Tapatalk Dr. Einstein, Dr. Edison here. I will expand upon your research tomorrow. Initial impression is good. Looks like a fine Chinese knockoff of the Yamaha. Do like the size. Doesn't have fuel and oil in it yet, but it will be a lot lighter than my Yamaha. Will be able to tell more tomorrow when I put my watt and amp toys on it to see, as Scotty would say, "Captain she can't take much more. The di-lithium crystals are beginning to crack!" For those of you worrying about carrying fuel in it while you tote it around. You could carry one of these around and pull a gallon of 100LL out of your tank. Pep Boys sell them. Not sure how they work, but they are magical and do the the job. Sent from my iPad using Tapatalk
M20kflyer99 Posted December 23, 2016 Report Posted December 23, 2016 This is smart. Get a small siphon.
Marauder Posted December 23, 2016 Report Posted December 23, 2016 Ok, it's tomorrow. Not bad performance. Will see how much the di-lithium crystals can handle tomorrow. My turbo XP Reiff system is supposed to be 600 watts. I will load that up and the heat lamp I used tonight to see if it can handle the rated 800 watts.Heat lamp:My Jeep heater:Sent from my iPad using Tapatalk
Marauder Posted December 23, 2016 Report Posted December 23, 2016 BTW - it is louder than my Yamaha unit.Sent from my iPad using Tapatalk
201er Posted December 23, 2016 Report Posted December 23, 2016 Still waiting to hear about how it starts at 15F. one guy put a Hobbs on it. Did you install an aspen? 1
M20kflyer99 Posted December 23, 2016 Report Posted December 23, 2016 Still waiting to hear about how it starts at 15F. one guy put a Hobbs on it. Did you install an aspen? I hear Aspen is still waiting on certification to operate as primary for the genset. Once they get that an unlock code price will be advertised.
carusoam Posted December 23, 2016 Report Posted December 23, 2016 Unlock code will be 2AMU... like everything else they have.. The magic siphon is a nifty device with a ball valve in it. Sucking not required, up and down motion will make it work. Expect to add oil every now and then, change it if it gets black, buy a new one before wasting money on an oil change... crummy humor, except that siphon explation... Best regards, -a-
Marauder Posted December 23, 2016 Report Posted December 23, 2016 Still waiting to hear about how it starts at 15F. one guy put a Hobbs on it. Did you install an aspen? No Aspen but thinking about a G5 to make sure it is level when I run it. It was in the high 20s when I started it yesterday. It was sitting outside the whole time. It started on the second pull.Sent from my iPad using Tapatalk
Marauder Posted December 23, 2016 Report Posted December 23, 2016 Unlock code will be 2AMU... like everything else they have.. The magic siphon is a nifty device with a ball valve in it. Sucking not required, up and down motion will make it work. Expect to add oil every now and then, change it if it gets black, buy a new one before wasting money on an oil change... crummy humor, except that siphon explation... Best regards, -a- They are pretty optimistic on oil consumption. The dipstick is behind the cover and requires 4 screws to be removed to check it. Sent from my iPad using Tapatalk 1
