Hi All,
I would like to replace landing light (NLI 4522 12v 250W) with LED landing light. I was hoping Aircraft Spruce could point me in the right direction with no success. Is it as easy as removing GE bulb and replacing with LED assuming I find the correct LED replacement?
1964 M20C single landing light pax side
Thanks,
GHW
I put a Whelen Parmetheus in my C. Works great! Be aware that polarity of the connection matters in the LED, but not on the old one. Other than that, it's a direct swap.
You'll need the PAR46 size.
Edited by Hank
One thing I've noticed is that I am maxed out on my downward adjustment screw and have it aimed a bit high still.  The frame of the Whelen compared to the GE bulb is definitely different. I may need to get a longer set screw to angle it down a bit more.
Putting in an LED landing light makes a lot of sense - no more burned out lights that you find out about as you are coming in at night. Much less current draw. Many people leave them on whenever the Master is on - makes a great recognition light.
whelen also sells par 46 bulbs led bulbs that go on other equipment that are about half of the ones that go on airplanes.....  I would doubt their tooling is different for the airplanes one.  The non airplane ones are about half the price.
1 hour ago, George said:
Thanks guys...Whelen Parmetheus it will be..
Hank-what is the small opening above your air filter?
Good question! I don't remember, and can't quickly find the answer . . .
It is a cooling air inlet that is ducted, via scat tubing, to blow on the engine driven fuel pump.
On the 65C, that cooling hole was ducted directly to the generator.  I don't recall the details where the fuel pump got it's cooling from.  Possibly a Y..?
Generators didn't have an integral fan like alternators have.
I think Anthony has a good point- both of my M20Cs had the alternator conversion, and I can't remember the last time I worked on a generator equipped M20.
My only question would be where does the pre-alternator M20E get its generator cooling from? The E/F models don't have this hole because of the ram air inlet.
Of course, the 50+ year old parts and service manuals don't have any information on it at all.
Get the Parmetheus Plus - it's about 40% brighter than the Parmetheus. I can get you 10% off through Spruce. PM me.
Will do Lancecasper....it will be December before I do anything. Still recovering from initial purchase / pre-purchase / getting it home / full set tires tubes plugs.........
GHW
Edited by George
Will do Lanecasper....it will be December before I do anything. Still recovering from initial purchase / pre-purchase / getting it home / full set tires tubes plugs.........
GHW
Welcome to owning an airplane :D
On 11/8/2016 at 8:10 PM, Yetti said:
whelen also sells par 46 bulbs led bulbs that go on other equipment that are about half of the ones that go on airplanes....... .  The non airplane ones are about half the price.
  I've heard  rumors  that some folks have installed the non-aviation Par46 Whelens and have had good luck with them....they even leave them on all the time and go many years without replacing them.....:)
  • 6 years later...
Talk to James Gallagher here on MS.  He can steer you the right way and give you a great price.
This week I think he is giving 10% off for SnF.   But you have to contact him directly.
On 11/8/2016 at 5:14 PM, George said:
Hi All,
Thanks,
GHW
This is what I put on my airplane.    Works fine.
https://www.amazon.com/gp/product/B009LQG64S
3 hours ago, mcarterak said:
If you're PAR-46 like me, get the new WAT G3.
Isn't that one 6A draw? I like the tiny current of my Original Parmetheus!
