MooneyBob Posted January 22, 2016 Report Posted January 22, 2016 It looks like my seals on my prop finally gave up in this cold weather. The annual is coming soon and I will call my MSC and ask if they can also handle the prop repair. My governor is leaking as well. The prop is 3 blade McCauley. It has 830 hrs since new and I believe it wasn't touched since then. What steps should I take? Ask my mechanics to handle it or remove it and send for overhaul? Is it safe to fly with this kind of leak to the shop about 15 minutes?
gsxrpilot Posted January 23, 2016 Report Posted January 23, 2016 Mine was doing the same and I flew it right up until the annual. Don Maxwell had it in for annual, pulled the prop off and sent it to the prop shop, got it back and reinstalled it. All during the annual. Not an A&P or anything like it, but my prop was blowing a little oil like that for probably 60 hours before we finally pulled it and got it fixed. 1
Shadrach Posted January 23, 2016 Report Posted January 23, 2016 2 hours ago, MooneyBob said: It looks like my seals on my prop finally gave up in this cold weather. The annual is coming soon and I will call my MSC and ask if they can also handle the prop repair. My governor is leaking as well. The prop is 3 blade McCauley. It has 830 hrs since new and I believe it wasn't touched since then. What steps should I take? Ask my mechanics to handle it or remove it and send for overhaul? Is it safe to fly with this kind of leak to the shop about 15 minutes? How do the blades look? I'd send it to East Coast Propellor and ask if they can reseal and paint rather than take meat off the blades. If the Gov is leaking at this time, I'd elect for a full governor overhaul.
N201MKTurbo Posted January 23, 2016 Report Posted January 23, 2016 You could probably fly it for another year, but it needs to be fixed. Just keep an eye on it.
OR75 Posted January 23, 2016 Report Posted January 23, 2016 In many parts of the country, because of the difficulty of getting rental space and cost, propeller shops have moved out of airports and pick up and bring back the prop once repaired or overhauled to you. You may want to check if there is a prop shop like that not too far from you ( say with 50 miles)
carusoam Posted January 23, 2016 Report Posted January 23, 2016 Hit up Cody with a PM. What is the third photo with the rubbed off rivet ends? hopefully it is just an aging seal causing the oil leak. Best regards, -a- 1
kpaul Posted January 23, 2016 Report Posted January 23, 2016 4 minutes ago, carusoam said: What is the third photo with the rubbed off rivet ends? The inside of the spinner? 1
Guitarmaster Posted January 23, 2016 Report Posted January 23, 2016 X2. Talk with, Cody Stallings. Sent from my XT1254 using Tapatalk
MooneyBob Posted January 23, 2016 Author Report Posted January 23, 2016 1 hour ago, carusoam said: Hit up Cody with a PM. What is the third photo with the rubbed off rivet ends? hopefully it is just an aging seal causing the oil leak. Best regards, -a- It is inside of the spinner.
Cody Stallings Posted January 23, 2016 Report Posted January 23, 2016 That is caused by a hardened blade O-Ring. Very easy fix. No need for a full blown O/H to fix that. I see 3-5 Props a month with that same Issue. Re-Seal is all that's needed to take care of that problem. Much Cheaper too! 5
