Guest Mike261
I just installed a jpg 900...
so i have all this stuff. don't know what anything is worth, will research later. thought i would make it available here first. ping me. mikeIMG_2393.thumb.JPG.4df7509f9f817a878c01cut b
Guest Mike261
fuel pressure or oil pressure...not sure.
either way they are both oil pressure senders.
my fuel pressure sensor failed and the only available replacement was an oil pressure sensor...it indicates less fuel pressure than actual as the bandwidth is different. This situation is what led me to the JPI 900, i was quoted a replacement fuel pressure sensor from mooney and it was over six grand and 56 week lead time. the used market was no better. All the gauges were old and flaky, now its pretty sweet.
mike
Guest Mike261
8 hours ago, Tony Armour said:
Does the fuel flow piece have... I guess it's called the transducer ?
The Shadin box i assume your talking about?
yes, its all there. worked fine when it came out. it has a flow sensor, the box and some connectors. I dont have the stuff yet its still all in a box at the airport and i havent had time to collect it and inventory it.
mike
  • 1 month later...
