peevee Posted August 25, 2015 Report Posted August 25, 2015 We have a K model, and I hate the fire extinguisher mount, it's right at the front of the pilot's seat and I'm constantly unbuckling the thing and subsequently losing the little metal rings. Has anyone found a better mount and or location for the thing? Quote
carusoam Posted August 25, 2015 Report Posted August 25, 2015 Do you want some pictures..? http://mooneyspace.com/topic/9110-fire-extinguisher-mounting/?hl=%2Bfire+%2Bextinguisher+%2Bmount There are a couple of threads on the same topic. Using the search with the forum button will dig them all up. I picked the one I knew had pictures and Ks... Best regards, -a- Quote
kortopates Posted August 25, 2015 Report Posted August 25, 2015 There is a drawing for mounting a fire extinguisher in your IPC or you can simply mount it on the floor longitudinally behind the emergency gear extension mechanism below the rear seat. Only a minor inconvenience for rear seat pax ingress and egress. Sent from my iPhone using Tapatalk Quote
peevee Posted August 25, 2015 Author Report Posted August 25, 2015 There is a drawing for mounting a fire extinguisher in your IPC or you can simply mount it on the floor longitudinally behind the emergency gear extension mechanism below the rear seat. Only a minor inconvenience for rear seat pax ingress and egress. Sent from my iPhone using Tapatalk that's probably the best spot. I'll see if we can get the mechanic to do it. I'm sure it'll require a W&B update. Quote
Parker_Woodruff Posted August 25, 2015 Report Posted August 25, 2015 Just be careful and don't have it drilled into the spar like I've seen happen before. Quote
peevee Posted August 25, 2015 Author Report Posted August 25, 2015 Do you want some pictures..? http://mooneyspace.com/topic/9110-fire-extinguisher-mounting/?hl=%2Bfire+%2Bextinguisher+%2Bmount There are a couple of threads on the same topic. Using the search with the forum button will dig them all up. I picked the one I knew had pictures and Ks... Best regards, -a- Didn't see those because I kept the search to the modern section, I figured the older planes didn't come with one like I assume the J and K did. I'm also assuming it was a factory install, but haven't pulled the POH to verify it's on the equipment list. I guess if it isn't I'd just remove it, but have mixed feelings on that. I guess that's another debate for another thread. Quote
peevee Posted August 25, 2015 Author Report Posted August 25, 2015 Just be careful and don't have it drilled into the spar like I've seen happen before. sounds expensive. I like our plane, I'd like to keep it Quote
dooleypster Posted August 25, 2015 Report Posted August 25, 2015 I went to the local fire extinguisher place to find a replacement for the one in my J model..... the only thing they had does NOT fit in the bracket that came with the plane. Â Anyone know where to get such a fire extinguisher? Â Quote
ArtVandelay Posted August 25, 2015 Report Posted August 25, 2015 There is a drawing for mounting a fire extinguisher in your IPC or you can simply mount it on the floor longitudinally behind the emergency gear extension mechanism below the rear seat. Only a minor inconvenience for rear seat pax ingress and egress. I mounted it vertically, just attached it to the kick panel. Quote
kortopates Posted August 26, 2015 Report Posted August 26, 2015 I mounted it vertically, just attached it to the kick panel.  Make sure its an airworthy installation, as in attached securely to withstand a some G's and not just secured with sheet metal screws into plastic. You don't want to see it become a flying missile in an off field landing! Quote
ArtVandelay Posted August 26, 2015 Report Posted August 26, 2015 Make sure its an airworthy installation, as in attached securely to withstand a some G's and not just secured with sheet metal screws into plastic. You don't want to see it become a flying missile in an off field landing! Thx, it's bolted, no screws: Sent from my iPhone using Tapatalk Quote
kortopates Posted August 26, 2015 Report Posted August 26, 2015 Nice, that's essentially a where the factory drawing placed it except laying down. I did mine laying on there as well but laying on the floor. Sent from my iPhone using Tapatalk Quote
