Hello, On my 89' J, I have a special edition stickers on the flywheel wheel cap ? Does someone tell me what 's inside this edition? post-11144-13619496443984_thumb.jpg By the way, what's the small white plastic piece use on the wheel ? Tanks
Special Edition means something different or upgraded from previous. Could be new paint scheme, updated avionics, etc.
That button is your map light on/off. There is a light bulb directly under it underneath the yoke.
Good luck!
Special Edition means something different or upgraded from previous. Could be new paint scheme, updated avionics, etc. That button is your map light on/off. There is a light bulb directly under it underneath the yoke. Good luck!
And I always thought it meant the owner was "special"! Sent from my iPad using Tapatalk
Well, it does. It means something different and upgraded from previous edition. New paint scheme, new upgraded owner, new fancy pilot, upgraded avionics, etc. The list goes on and on!
I have recently looked at two 1989 M20J's........they both had a "Special Edition" emblem on the yokes.  I would not be surprised if this was found on all 89 models.
