Derrickearly Posted May 10 Report Posted May 10 Looking for a trim tube with part number 915026-009 for my 1976 M20F. It’s -56 in the parts catalog figure.
varlajo Posted May 10 Report Posted May 10 I got mine from Lubbock Aero last year, $254.21. Call Richard Jackson, (806) 747-5101. 1
Ragsf15e Posted May 10 Report Posted May 10 I had to get one from Mooney a few years ago. Call top gun msc and see about ordering one. 1
varlajo Posted May 10 Report Posted May 10 15 minutes ago, Ragsf15e said: I had to get one from Mooney a few years ago. Call top gun msc and see about ordering one. Did you add any reinforcement to the trim tube or some sort of a sleeve to the bulkhead? 1
Ragsf15e Posted May 10 Report Posted May 10 7 minutes ago, varlajo said: Did you add any reinforcement to the trim tube or some sort of a sleeve to the bulkhead? There is supposed to be a “sacrificial block” where it goes through there, so yes, they put that in with the new one. That damage is actually pretty common. The newer models have some kind of a wrap on the tube and the “lining” in the hole. 1
varlajo Posted May 10 Report Posted May 10 1 minute ago, Ragsf15e said: There is supposed to be a “sacrificial block” where it goes through there, so yes, they put that in with the new one. That damage is actually pretty common. The newer models have some kind of a wrap on the tube and the “lining” in the hole. Mine didn't have the block, but there was quite a bit of sacrificial speed tape on the old tube. 2
MikeOH Posted May 10 Report Posted May 10 2 minutes ago, Ragsf15e said: That damage is actually pretty common. The newer models have some kind of a wrap on the tube and the “lining” in the hole. I was lucky to notice the wear on mine before the tube was too far gone. My A&P added a teflon 'bushing' to the hole and 'wrapped' the tube which stopped the wear. 3
Derrickearly Posted May 10 Author Report Posted May 10 2 hours ago, Ragsf15e said: There is supposed to be a “sacrificial block” where it goes through there, so yes, they put that in with the new one. That damage is actually pretty common. The newer models have some kind of a wrap on the tube and the “lining” in the hole. This is the plan for the new part.
Derrickearly Posted May 10 Author Report Posted May 10 10 hours ago, varlajo said: I got mine from Lubbock Aero last year, $254.21. Call Richard Jackson, (806) 747-5101. I sent them an email via their website. Hopefully, I'll hear from them on Monday.
M20F-1968 Posted May 11 Report Posted May 11 The "sacrificial blocl" is made from bakelite type material and is quite abrasive in and of itself. When I rebuilt my plane I made new nylon blocks with DER signoff. Much less abrasive and have not had issues. John Breda 4
Hradec Posted May 11 Report Posted May 11 If you can't find a tube. I've heard of hangar elves buying tubing. Cut to length and carefully drill to match the old ujoints. Pleny of parts in the bkneyards but a lot have the same damage 2
Derrickearly Posted May 12 Author Report Posted May 12 23 hours ago, Hradec said: If you can't find a tube. I've heard of hangar elves buying tubing. Cut to length and carefully drill to match the old ujoints. Pleny of parts in the bkneyards but a lot have the same damage What are the specifications for the tube? OD, ID, and material?
Hradec Posted May 12 Report Posted May 12 You can either cut down a longer used tube if it is one of your shorter tubes that are damaged. I may have got the material spec from frank Crawford at mooney I'm not sure. I checked the places I order from and did not see it in my history. If I find it I will let you know. Search mooneyspace there may be some more info out there. If I recall ID of the tube is machined to a larger id just at the end fir the bushing and ujoint 1
Derrickearly Posted May 13 Author Report Posted May 13 Update: Mooney came through. The factory part is shipping presently! I was expecting another 8 weeks. 3
phxcobraz Posted May 13 Report Posted May 13 5 hours ago, Derrickearly said: Update: Mooney came through. The factory part is shipping presently! I was expecting another 8 weeks. How much they want now? Mine was a bit worn at annual but not terrible, so I am looking for options for the future.
