FJC Posted May 16, 2024 Report Posted May 16, 2024 (edited) Please PM me if you have one or will soon have one! Thank you. Freddy Edited May 16, 2024 by FJC Quote
wombat Posted May 16, 2024 Report Posted May 16, 2024 I don't have one I can afford to get rid of, but the one you have (assuming you have one that is not working) you can probably get it repaired. Quote
laytonl Posted May 16, 2024 Report Posted May 16, 2024 I believe I have one but will be out of the country for two weeks. I’ll check when I get back. If you still need it, pm me so I’ll remember to check. Lee Quote
LANCECASPER Posted May 16, 2024 Report Posted May 16, 2024 4 hours ago, wombat said: I don't have one I can afford to get rid of, but the one you have (assuming you have one that is not working) you can probably get it repaired. If you're going to send a servo off to Bendix King for an overhaul it will be enormously less money to buy a used one that was taken out for an autopilot replacement. The last I heard a Bendix King overhaul on a servo was around $7000. I see used ones all over the place for $500 each, sometimes $1000 for the whol system that came out. If you're going to keep a KFC150, not a bad idea to stock up on at least one extra of each of the servos at bargain pricing. Quote
wombat Posted May 16, 2024 Report Posted May 16, 2024 13 minutes ago, LANCECASPER said: If you're going to send a servo off to Bendix King for an overhaul it will be enormously less money to buy a used one that was taken out for an autopilot replacement. The last I heard a Bendix King overhaul on a servo was around $7000. I see used ones all over the place for $500 each, sometimes $1000 for the whol system that came out. If you're going to keep a KFC150, not a bad idea to stock up on at least one extra of each of the servos at bargain pricing. I would not recommend sending it to BK. go to autopilotscentral.com and have them repair it. But yeah, just buying and stocking a set of spares would be a pretty good idea too. Quote
Pinecone Posted May 20, 2024 Report Posted May 20, 2024 If anyone else needs one, or any other KAP-150 parts I have them from my plane. And avionics shop will tag. Quote
