amekler Posted February 11, 2024 Report Posted February 11, 2024 I have noticed an air leak at the top rear of my door. I was thinking of replacing with an inflateable seal( had one in my M20J) but the bob fields website says m20A through m20K. Will it fit a M20M? Any thoughts on Knots2U seals? Alan N9127M Quote
Danb Posted February 11, 2024 Report Posted February 11, 2024 43 minutes ago, amekler said: I have noticed an air leak at the top rear of my door. I was thinking of replacing with an inflateable seal( had one in my M20J) but the bob fields website says m20A through m20K. Will it fit a M20M? Any thoughts on Knots2U seals? Alan N9127M Yes it will I had one on my Bravo, I have a panel controlled one from FieldS I haven’t installed still in the box, I’d consider sending if you want. D Quote
amekler Posted February 11, 2024 Author Report Posted February 11, 2024 I was going to go with the basic manual one do you have a price for yours? I assume it is the deluxe alan Quote
Jetpilot86 Posted February 11, 2024 Report Posted February 11, 2024 How much difference does it make in decibels? I know I’m around 100-105db’s in my Bravo. Quote
Danb Posted February 11, 2024 Report Posted February 11, 2024 2 hours ago, amekler said: I was going to go with the basic manual one do you have a price for yours? I assume it is the deluxe alan Yes deluxe Quote
Fritz1 Posted February 11, 2024 Report Posted February 11, 2024 I bought a factory door seal three or four years ago but never installed it, glued a strip of 1/4" hollow windlace material from the aviation isle of home depot to the straight bottom section of the door seal where there was a small leak and nursed the rest of the seal with rubber conditioner, installing the new seal is a tricky job as I hear, just did not muster the gumption since mine stopped leaking with minimum effort. Since the door is a fragile contraption does the small inflation pressure of inflatable seal cause any warping of the door and excessive pressure on the door locks?? thoughts?? Quote
amekler Posted February 13, 2024 Author Report Posted February 13, 2024 I called about the inflateable Door seal it is not stc for m20m and would require a field approval Alan Quote
PhateX1337 Posted February 14, 2024 Report Posted February 14, 2024 I got this done at annual last month, was able to get a field approval no issue. Frustrating to have to do that, but it wasn't a big deal. It makes a big difference in sound levels as others have mentioned. Don't have measured before/after dB readings though. Quote
amekler Posted February 14, 2024 Author Report Posted February 14, 2024 I've been told here in NH the Portland FSDO is understaffed for field approvals but I'll make some calls. Alan Quote
Jetpilot86 Posted February 26, 2024 Report Posted February 26, 2024 On 2/14/2024 at 3:24 PM, PhateX1337 said: I got this done at annual last month, was able to get a field approval no issue. Frustrating to have to do that, but it wasn't a big deal. It makes a big difference in sound levels as others have mentioned. Don't have measured before/after dB readings though. Do you have an after? I think I was 105 without, and will get to check again next week. Quote
Pinecone Posted February 26, 2024 Report Posted February 26, 2024 What happens if you open the door without deflating the seal??? Quote
slowflyin Posted February 26, 2024 Report Posted February 26, 2024 1 hour ago, Pinecone said: What happens if you open the door without deflating the seal??? Nothing but you will notice resistance on the door handle. It's enough to give pause. Quote
Pinecone Posted February 26, 2024 Report Posted February 26, 2024 More worried with someone else in the right seat Quote
PhateX1337 Posted February 26, 2024 Report Posted February 26, 2024 19 hours ago, Jetpilot86 said: Do you have an after? I think I was 105 without, and will get to check again next week. Will try to get some readings this weekend - not sure. 1 Quote
