Hi!
I'm not sure if im missing remembering or not. We took the float out to do a tank repair. After putting the float back in, the reading on the gauge was past the top.
There is only one wire going to the sender. I thought the problem was a bad ground, so I attached a wire to the post and the other end to a screw. I managed to short the gauge now so that it only reads 0. I looked in the manual and its of no help how this goes back together. I'm pretty sure I looked at the other side and it looks like I put it together correctly.  Any ideas? Thanks in advance!!
I'm not a mechanic but I'm dealing with similar issues.  I think the C may have one sender per tank.  My F has two per tank in series.  I think they are all 0-30 ohms.  You could move the sender through its operating range and check that between the post and ground.  Your second pic is definitely not correct; you answered your own question about the short to ground.  I'm guessing it's installed in the same orientation it was removed.  Air Parts of Lockhaven overhauls those senders and gages.  It's not cheap but cheaper than new.
You'll get good guidance from someone here.  I'm not an expert.
Only wire to the center post should be the hot wire. When airpark overhauled mine, they make it so you cannot remove it. I had to add a ground on mine to make sure it reads properly. A full reading is a no ground situation.
in your pic, the gasket or screws are leaking so you’ll need to address that…
BTW, Air Parts doesn’t send a gasket for the sender so you need to ask for one…
-Don
-Don
The five screws weren’t enough for a good ground?  How did you add a ground?  From a screw to?
No, screw wasn’t enough (it should have but wasn’t). I added one from one of the bolts to a common ground. It’s in the pics.
-Don
I’m just not sure where the ground should make contact? It doesn’t seem to from the screw holes themselves.
I’m not sure, I don’t think so. What im really not sure about it where the ground contact point is on the sender.
-Don
-Don
That was a mistake! Forgot to tighten the screws down again after screwing around with the probe and then went flying. It’s not straight forward what orientation the probe should be in either…
  • 2 months later...
Thanks all for the feedback!! I'm finally getting back to the issue since its in annual now..
I took the sender out and hooked only the center wire up, and then grounded the casing.
The gauge reads 1/2 full when empty. When I lift the float to full, the gauge reads way past full.
The gauge does go up and down with movement of the float up and down. The zero is just off!
I tried to bend the stop a little, but it only seems to make things worse. Onto repair, next step try to see what the resistance is?
Thank You!!!
Its  30 ohm system
Hook a 15 ohm (10%- gold stripe) resistor the center wire  and the other end to ground and you should see 1/2 tank
on the gage.
The lever on the tank transmitter should go from near 0 ohms to about 30 ohms smoothly
If it jumps around a lot during the travel its in need of work.
Don't tighten the gasket screws down too tight or you will deform the mount hole and have a heck of a time trying
to seal the transmitter even with a new gasket
I always use a LITTLE aviation Titeseal gasket sealer on them when I assemble them.
41 minutes ago, cliffy said:
Its  30 ohm system
on the gage.
@jM20 says "The gauge reads 1/2 full when empty. When I lift the float to full, the gauge reads way past full."  Is there supposed to be a resistor in the circuit?
Keep in mind that various Mooney M20C model years especially in mid 60's had different  size fuel tanks. Some fuel tanks were 52 gallon capacity, which has  26gal  156Lbs a side while other earlier years, I think some where 48 gallons 24 gallons /144lbs a side.  I believe the tank sender resistance changed as well.  my 67'C 52 gal  156Lbs a side indicated on fuel Gauge is a 30Ω.  I am not sure but I think that the  later year 'C' models like in the 70's may change the resistances for the fuel senders again.
James '67C
AFAIK ALL Mooney fuel sensors are 30 ohms at the top of their stroke.  Even on the ones with 2 senders per tank.
With 2 senders, they are wired in series, so full on the gauge is 60 ohms resistance.
