NicoN Posted March 4, 2023 Report Posted March 4, 2023 Some time ago, I had trouble with my trim switch (see old posting; it is NOT a split switch but thsi rocker model which you have to press to engage the clutch). I repired the wiring and anything was fine. Now we have trouble again. This time, this little spring metal "plunger" on the clutch microswitch is broken, therefore the clutch does not engage but the motor runs. The switch assembly is in good shape, so it would be nice to only replace one (or all 3 of these microswitches. But which type? We see a printing on it, but it is almost not readable. Can be something like "MM" or "MK" I know there is a company "MK microswithces" Does anybody know the type of these microswitches? The trim switch is a factory-Mooney thing and has nothing to do with the auto-pilot. P.S.: And - I am not taking drugs while aksing for the part of this switch. At least not more or something else :-)
N201MKTurbo Posted March 4, 2023 Report Posted March 4, 2023 They are probably made by MicroSwitch which is a Honeywell company.
NicoN Posted March 4, 2023 Author Report Posted March 4, 2023 I just found this: https://www.ckswitches.com/media/1363/mm.pdf That would match my "MM" and they look similar. Should be the L0 type
Fly Boomer Posted March 4, 2023 Report Posted March 4, 2023 Also may help to search LittleFuse who apparently bought C&K.
LANCECASPER Posted March 4, 2023 Report Posted March 4, 2023 5 hours ago, Fly Boomer said: Also may help to search LittleFuse who apparently bought C&K. I believe it’s Littel Fuse 2
ElkoRandy20J Posted March 5, 2023 Report Posted March 5, 2023 Last July I got a new switch thru my Avionics Shop in Idaho. This was for a 1979 J Model with Century a/p. My switch looks very similar to the picture (and functional description). That part no. was 30413-13 and cost $627.
Fly Boomer Posted March 5, 2023 Report Posted March 5, 2023 33 minutes ago, LANCECASPER said: I believe it’s Littel Fuse You are right, of course, but without the space.
