mooney2201 Posted January 30, 2023 Report Posted January 30, 2023 Has anybody replaced the battery in their gtn 750..How much does garmin charge
toto Posted January 30, 2023 Report Posted January 30, 2023 I don’t think I knew there was a battery in the 750 … is it just like a little CR 2032 to keep the time?
1980Mooney Posted January 30, 2023 Report Posted January 30, 2023 Here is the replacement on a GTN 650. It is larger. http://www.rvplane.com/?categoryid=10000&dayid=1456
PT20J Posted January 30, 2023 Report Posted January 30, 2023 Interesting -- how do you know it needs replacement? It's a primary cell, so it doesn't get recharged.
PeteMc Posted January 30, 2023 Report Posted January 30, 2023 1 hour ago, mooney2201 said: How much does garmin charge Is that a Garmin repair or do you just go into a local Garmin shop?
toto Posted January 30, 2023 Report Posted January 30, 2023 44 minutes ago, 1980Mooney said: Here is the replacement on a GTN 650. It is larger. http://www.rvplane.com/?categoryid=10000&dayid=1456 Fascinating. I had no idea that this was a thing.
PT20J Posted January 30, 2023 Report Posted January 30, 2023 Apparently the internal battery is used to keep some memory alive to store the GPS constellation almanac. 1
1980Mooney Posted January 30, 2023 Report Posted January 30, 2023 4 hours ago, PT20J said: Interesting -- how do you know it needs replacement? It's a primary cell, so it doesn't get recharged. "Internal Clock Battery Low" warning and slow acquisition 4 hours ago, PeteMc said: Is that a Garmin repair or do you just go into a local Garmin shop? Either. 3 hours ago, PT20J said: Apparently the internal battery is used to keep some memory alive to store the GPS constellation almanac. Garmin does not want owners changing the battery and the Dealer provided procedures are not exactly easy to find. From our friends at Beechtalk: "My GTN650 was installed in 2013 and has now begun displaying the "Internal Clock Battery Low" warning all the time. Maybe its my imagination, but it also already seems to be a little slower in satellite acquisition on startup. I was surprised when my (small, but busy) avionics shop said "I don't know, I've never replaced one yet" in answer to my inquiries. They are checking with Garmin, but not yet getting any clear info about their ability to do the battery change vs. the need to send it back to Garmin ($1,000 flat repair fee if I'm not mistaken). The ICA states that we should expect around 10 years out of the battery, so that's one surprise. But it also says it can be replaced at an authorized repair shop or the factory. Of more concern is the lack of info I'm finding so far on what should be a routine maintenance item for a very common instrument. ICA also states that 1-2 months will pass after first appearance of the warning message before critical low state exists, and even then operational symptoms will be limited to slow acquisition only." "Dealer GTN 650 Maintenance Manual, 190-01004-01, Rev. 02 (downloaded from Garmin Dealer Resource Center) for full instructions for replacing the battery (page 5-6). The part number for the battery is in the Service Parts List on page 7-1. Only simple tools are required. No soldering." https://www.beechtalk.com/forums/viewtopic.php?f=21&t=152260
PeteMc Posted January 30, 2023 Report Posted January 30, 2023 4 hours ago, 1980Mooney said: But it also says it can be replaced at an authorized repair shop or the factory. I thought it could be swapped out by a Av Shop. Let us know what your shop finally finds. My guess is that they're supposed to backup the config, change the battery and confirm the config is okay and you're done. But then that would be too simple and logical. So do let us know how many hoops and how high you had to jump. Eventually all of us with a GTN will need to go through this, so the process will be nice to know.
mooney2201 Posted January 30, 2023 Author Report Posted January 30, 2023 Golf coast avionics.. Said it would be $35 for the battery. And a 150 labor
1980Mooney Posted January 30, 2023 Report Posted January 30, 2023 1 hour ago, mooney2201 said: Golf coast avionics.. Said it would be $35 for the battery. And a 150 labor Don't forget shipping w/ insurance both ways.......another $80?...more?!
PT20J Posted January 30, 2023 Report Posted January 30, 2023 $150 labor sounds like an hour at shop rate which is probably the minimum charge and not unreasonable. But since it is easily field replaceable, I would probably buy a battery, remove the cover and replace the battery myself since it doesn’t require more skill or knowledge than operating a screwdriver.
PeteMc Posted January 31, 2023 Report Posted January 31, 2023 Depending how long ago you got a Software Update, you might as well have them update everything. Even if they don't usually charge for an update, at least you'll feel like you're getting more for you money.
glbtrottr Posted January 31, 2023 Report Posted January 31, 2023 I remember affordable avionics in Chino wanted over $500 to do this without the software upgrade…Sent from my iPhone using Tapatalk
mooney2201 Posted January 31, 2023 Author Report Posted January 31, 2023 You must save everything to configure module...or you will loose all settings, and I don't need that aggravation to redo all the settings
hais Posted January 31, 2023 Report Posted January 31, 2023 I had to change the battery once for a 530. The shop charged less than $100. I wasn't surprised that the unit needed a battery - presumably there's a clock that needs to run. Almanac and other data can be stored without needing power. But I was shocked to discover that the unit had no internal memory - or so I was told. I couldn't wrap my head around that design decision. Reading the 750/650 manual, I saw that a memory card is required to operate...again a puzzling design choice.
PT20J Posted January 31, 2023 Report Posted January 31, 2023 20 minutes ago, hais said: I had to change the battery once for a 530. The shop charged less than $100. I wasn't surprised that the unit needed a battery - presumably there's a clock that needs to run. Almanac and other data can be stored without needing power. But I was shocked to discover that the unit had no internal memory - or so I was told. I couldn't wrap my head around that design decision. Reading the 750/650 manual, I saw that a memory card is required to operate...again a puzzling design choice. Although the manual does say the SD card must be in the unit, once it downloads an update to internal memory it does run fine with the card removed. The only reason I can think that it needs the card is for backup if the internal memory has a problem, but who knows -- Garmin doesn't explain this.
PT20J Posted January 31, 2023 Report Posted January 31, 2023 36 minutes ago, mooney2201 said: You must save everything to configure module...or you will loose all settings, and I don't need that aggravation to redo all the settings You should save settings to the configuration module every time a change is made. If the configuration is up to date there is no problem losing data. But, it never hurts to save again before doing anything. Also, I keep a backup hard copy of the configurations I got from the installer just in case.
PeteMc Posted January 31, 2023 Report Posted January 31, 2023 3 hours ago, PT20J said: The only reason I can think that it needs the card is for backup if the internal memory has a problem, but who knows -- Garmin doesn't explain this. There is an internal SD Card for the backups, at least for the Xi units, it is taped inside to the side of the frame. I'm pretty sure my Avionics guy said metal tape, but he definitely said you'll see it on the side if the cover is off.
rbp Posted January 31, 2023 Report Posted January 31, 2023 3 hours ago, PT20J said: Although the manual does say the SD card must be in the unit, once it downloads an update to internal memory it does run fine with the card removed. The only reason I can think that it needs the card is for backup if the internal memory has a problem, but who knows -- Garmin doesn't explain this. Garmin database concierge will make one SD card that I can use to update the nav databases in my G3Xs, GTN750 and GNC355, instead of using 4 separate cards. this is of course more important for fleets. the card definitely does not need to be in the unit to operate, and goes against the default database concierge behavior
PT20J Posted January 31, 2023 Report Posted January 31, 2023 40 minutes ago, rbp said: Garmin database concierge will make one SD card that I can use to update the nav databases in my G3Xs, GTN750 and GNC355, instead of using 4 separate cards. this is of course more important for fleets. the card definitely does not need to be in the unit to operate, and goes against the default database concierge behavior Do you keep a card in the G3X for data logging? Having a card in the GTN is required per the limitations section of the AFMS so it’s technically a violation of FAR 91.9 not to have it although it would have to be a very thorough ramp check to notice that
rbp Posted January 31, 2023 Report Posted January 31, 2023 6 hours ago, PT20J said: Do you keep a card in the G3X for data logging? Having a card in the GTN is required per the limitations section of the AFMS so it’s technically a violation of FAR 91.9 not to have it although it would have to be a very thorough ramp check to notice that yes, I keep SD cards in all the devices!
Pinecone Posted January 31, 2023 Report Posted January 31, 2023 12 hours ago, glbtrottr said: I remember affordable avionics in Chino wanted over $500 to do this without the software upgrade… Not very affordable.
jetdriven Posted January 31, 2023 Report Posted January 31, 2023 14 hours ago, 1980Mooney said: Don't forget shipping w/ insurance both ways.......another $80?...more?! I shipped a G430, insured for four grand, 150 nautical miles away and it was $110 with UPS so it's probably more like 150 each way. 1
