Boilermonkey Posted November 12, 2022 Report Posted November 12, 2022 Does anyone know the bulb type that is in the WING aft position light? Figure 33-5 i nthe SM describes it, but I can't find the part number and I don't think it is the standard W1290 that is used in the other part of the wing lights and tail. - Quote
PilotX Posted November 13, 2022 Report Posted November 13, 2022 Hangar elves found these. https://www.amazon.com/gp/product/B01MZHC4OM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 1 Quote
rbp Posted November 13, 2022 Report Posted November 13, 2022 does anyone have LED replacement bulbs? LED recogs are on order. its just these "2" bulbs that are still incandescent on mine Quote
Pinecone Posted November 14, 2022 Report Posted November 14, 2022 13 hours ago, PilotX said: Hangar elves found these. https://www.amazon.com/gp/product/B01MZHC4OM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 1 hour ago, rbp said: does anyone have LED replacement bulbs? LED recogs are on order. its just these "2" bulbs that are still incandescent on mine See above Quote
kortopates Posted November 14, 2022 Report Posted November 14, 2022 I wouldn’t replace the rear white wingtiplights. If you do, and have LED’s for Nav lights, you’ll find that the gear down light becomes always dimmed (without Nav lights on) and will have to correct that or not be able to see you gear down light in daytime.I have only had to change one rear wing tip bulb in well over 20 years of ownership. Frankly IMO it’s not worth replacing them with LEDs and then needing to install a relay to correct the always dimmed gear down light. Sent from my iPhone using Tapatalk 2 Quote
rbp Posted November 14, 2022 Report Posted November 14, 2022 6 minutes ago, kortopates said: you’ll find that the gear down light becomes always dimmed why is this? Quote
PilotX Posted November 14, 2022 Report Posted November 14, 2022 9 hours ago, kortopates said: I wouldn’t replace the rear white wingtip lights. If you do, and have LED’s for Nav lights, you’ll find that the gear down light becomes always dimmed (without Nav lights on) and will have to correct that or not be able to see you gear down light in daytime. I have only had to change one rear wing tip bulb in well over 20 years of ownership. Frankly IMO it’s not worth replacing them with LEDs and then needing to install a relay to correct the always dimmed gear down light. Sent from my iPhone using Tapatalk Something to this but never figured out why. I have LEDs all around so I leave everything on except strobes. Everything is dim but if you know where to install the relay I would love to know the fix. Quote
tls pilot Posted November 18, 2022 Report Posted November 18, 2022 did the LED lights work for this aft wing lamp? Quote
Boilermonkey Posted November 20, 2022 Author Report Posted November 20, 2022 Looks like they will, but when I took the cover off the old bulb has a clip with safety wire on it holding the bulb in place and some silicon glue holding the glass cover in place. Since I had neither silicon glue of thin safety wire I had to abort today. I'll try again later. Quote
Boilermonkey Posted August 7, 2023 Author Report Posted August 7, 2023 Does anyone know the original halogen bulb wattage or part number? I replaced with the LEDs that someone suggested, but now get static on the radios. Quote
LANCECASPER Posted August 7, 2023 Report Posted August 7, 2023 55 minutes ago, Boilermonkey said: Does anyone know the original halogen bulb wattage or part number? I replaced with the LEDs that someone suggested, but now get static on the radios. https://www.aircraftspruce.com/catalog/elpages/whelen28vlamp.php Quote
Fly Boomer Posted August 7, 2023 Report Posted August 7, 2023 1 hour ago, Boilermonkey said: Does anyone know the original halogen bulb wattage or part number? I replaced with the LEDs that someone suggested, but now get static on the radios. Some LED lamps have a simple buck/boost circuit that generates a signal. Especially the cheaper ones. There is at least one topic around here discussing the possibility that you may need to replace the receptacle when you replace the lamp. Quote
Boilermonkey Posted August 29, 2023 Author Report Posted August 29, 2023 Thanks, I replaced the LED that were recommended on MS, but gave me static on the radios. Went back to the halogens and everything went back to normal. 1 Quote
