DCarlton Posted September 13, 2023 Report Posted September 13, 2023 3 hours ago, OSUAV8TER said: I just received more of these G3 LED landing and taxi lights and have an excellent inventory of them. https://www.gallagheraviationllc.com/WAT-14V28V-G3-PAR-36-LED-Landing-Light_p_189.html <-- Link to the PAR-36 (4.5" diameter bulb) G3 LED Landing Light https://www.gallagheraviationllc.com/WAT-14V28V-G3-PAR-36-LED-Taxi-Light_p_190.html <-- Link to the PAR-36 (4.5" diameter bulb) G3 LED Taxi Light https://www.gallagheraviationllc.com/WAT-G3-PAR-46-LED-Landing-Light_p_134.html <-- Link to the PAR-46 (5.75" diameter bulb) G3 LED Landing Light A bit confused on the various options. If I install LED wingtip and tail lights with the strobe function, can I remove my existing belly strobe? Quote
OSUAV8TER Posted September 13, 2023 Author Report Posted September 13, 2023 5 hours ago, DCarlton said: A bit confused on the various options. If I install LED wingtip and tail lights with the strobe function, can I remove my existing belly strobe? To answer your question it depends. Technically, yes if you have a TSO certified wingtip and tail strobe light, you do not need a beacon light. The "it depends" part requires you to take a look at your POH or TCDS to see if the belly beacon is part of the aircraft certification. Secondly, it will require you to run the strobe lights all the time, which on the ground or if you fly into clouds it can become a distraction. If you want to talk more you can email me at gallagheraviationllc@gmail.com or we can talk at 1-833-425-5288. James 1 Quote
slowflyin Posted October 9, 2023 Report Posted October 9, 2023 Pic of my departure early this morning. Two G3 landing, two G3 taxi lights and two led recognition lights. Couldn't be more pleased. Thanks James! 1 Quote
OSUAV8TER Posted October 9, 2023 Author Report Posted October 9, 2023 12 minutes ago, slowflyin said: Pic of my departure early this morning. Two G3 landing, two G3 taxi lights and two led recognition lights. Couldn't be more pleased. Thanks James! That is impressive! Nice projection down the runway and excellent illumination to the left and right of the aircraft. James Quote
slowflyin Posted October 10, 2023 Report Posted October 10, 2023 14 hours ago, OSUAV8TER said: That is impressive! Nice projection down the runway and excellent illumination to the left and right of the aircraft. James I adjusted per the Mooney SM. Considering the beam presentation is so different compared to the old GE bulbs I wasn't really sure what kind of results to expect. Pleasantly surprised to say the least. Quote
OSUAV8TER Posted March 8, 2024 Author Report Posted March 8, 2024 I have an excellent inventory of these G3 LED landing and taxi lights. Most Mooney aircraft require the PAR-36 size unless your Mooney has a single landing light on the nose, then is needs a PAR-46 size lamp. https://www.gallagheraviationllc.com/WAT-14V28V-G3-PAR-36-LED-Landing-Light_p_189.html <-- G3 PAR-36 LED Landing Light Link https://www.gallagheraviationllc.com/WAT-14V28V-G3-PAR-36-LED-Taxi-Light_p_190.html <-- G3 PAR-36 LED Taxi Light Link https://www.gallagheraviationllc.com/WAT-G3-PAR-46-LED-Landing-Light_p_134.html <-- G3 PAR-46 LED Landing Light Link Quote
OSUAV8TER Posted May 21, 2024 Author Report Posted May 21, 2024 I just received more PAR-36 size (4.5" diameter) G3 LED landing and taxi lights so if you order today, they ship today. I also have an excellent inventory of the PAR-46 size (5.75" diameter) G3 LED landing lights in stock. If you have a Mooney with a single landing light on the nose, it is a PAR-46 size. If you have two on the nose, they are PAR-36 size. If you have two in each wing, they are also PAR-36 size. These are the best LED landing and taxi lights on the market and are easy to install. https://www.gallagheraviationllc.com/WAT-14V28V-G3-PAR-36-LED-Landing-Light_p_189.html <-- G3 PAR-36 LED Landing Light Link https://www.gallagheraviationllc.com/WAT-14V28V-G3-PAR-36-LED-Taxi-Light_p_190.html <-- G3 PAR-36 LED Taxi Light Link https://www.gallagheraviationllc.com/WAT-G3-PAR-46-LED-Landing-Light_p_134.html <-- G3 PAR-46 LED Landing Light Link gallagheraviationllc@gmail.com <-- Email me for quotes or questions 1-833-425-5288 <-- Call, please leave a voicemail if I do not answer 513-401-6495 <-- Call/Text/MMS, please leave a voicemail if I do not answer. G3 LED landing light on right, and G3 LED taxi light on the left Quote
OSUAV8TER Posted August 22, 2024 Author Report Posted August 22, 2024 I have an excellent inventory of these G3 LED landing and taxi lights in the PAR-36 and PAR-46 size ready to ship. These are the best LED lamps on the market, especially for the price! https://www.gallagheraviationllc.com/-LED-Landing-Taxi-and-Recognition-Lights_c_26.html <-- Link to all landing, taxi, and recognition lights gallagheraviationllc@gmail.com <-- Email me with questions 1-833-425-5288 <-- Call me here, please leave a voicemail if I do not answer 513-401-6495 <-- Call/Text/MMS me here, please leave a voicemail if I do not answer Quote
