WAFI Posted December 16, 2021 Report Posted December 16, 2021 I came a cross an older post a couple days ago but can't seem to located it after scouring this forum for hours. Someone was talking about an overhaul shop up north maybe Illinois, that start with a J*****ll but very cheap prices, very cheap!!! Like sub 20K for a IO-360
kpaul Posted December 16, 2021 Report Posted December 16, 2021 20 minutes ago, WAFI said: I came a cross an older post a couple days ago but can't seem to located it after scouring this forum for hours. Someone was talking about an overhaul shop up north maybe Illinois, that start with a J*****ll but very cheap prices, very cheap!!! Like sub 20K for a IO-360 I assume you are talking about Jewell Aviation in Kennett Missouri. https://www.jewellaviation.com/default.htm
ToddCC22 Posted December 16, 2021 Report Posted December 16, 2021 I think this is what you were referring to. Jewell Aviation in MO. They did mine just before I took delivery from Maxwell.
carusoam Posted December 16, 2021 Report Posted December 16, 2021 When the local search function doesn’t give results…. Use Google to search instead… local search needs at least four characters… Google can find three…. works when trying to find things like TKS or ELT… -a- 1
Hank Posted December 16, 2021 Report Posted December 16, 2021 43 minutes ago, carusoam said: When the local search function doesn’t give results…. Use Google to search instead… local search needs at least four characters… Google can find three…. works when trying to find things like TKS or ELT… -a- Just put ":mooneyspace" at the end of your Google search string. Unless our database and internet presence is large enough now that that isn't needed anymore. 1
tmo Posted December 17, 2021 Report Posted December 17, 2021 site: mooneyspace.com is what you want to append to the query you give your favorite search engine, be it DuckDuckGo, Bing or Google.
