I just use the basic:
Climb 110
Fuel burn 13
Climb rate 800
Cruise TKS 145
Cruise Fuel 9.5
Decent TAS 145
Decent Burn 5
Decent rate 500
3 minutes ago, TNIndy said:
Thanks, when I try to select an altitude I’m limited to 11,000 feet with the standard M20F profile
You’re going to have to customize it. Your engine is more thermally efficient than anything in the standard drop down menu. So no profile will fit. Climb might be close to a 231 but speeds will be slower.
I customized the profile for my C. The fuel flow was too high a d speeds were off, and I've never ever reduced power to descend near cruise speed--all I do is push for 500 fpm, trim for hands off and every now and then reduce MP and richen mixture to maintain cruise MP and EGT values.
