Hello,
My Mooney is at the annual and it is supposed to be ready tomorrow. My A&P needs the solenoid 4085-20 now.
We are researching and any help/idea is appreciated.
Thanks!
  On 4/1/2021 at 3:06 PM, FastTex said:
Hello,
Thanks!
Expand
Where is it and what does it do?  I'm trying to get more familiar with my Brittain system.  I don't think my '67 has one.  Thanks.
Expand
No it doesn’t.
but I was also looking for one so i could disconnect PC system with the switch on a new style yokes i have waiting to be installed.
It is a rare part...
  On 4/2/2021 at 5:23 AM, Igor_U said:
No it doesn’t.
Expand
Understand thanks for the info.
Does it look like this?  If so I've got one.  The mounting bracket is broken, but easily fixed.
Expand
 FastTex....   Is it pn 4085-2C you’re looking for?  The Doc must be clairvoyant!
image.thumb.png.96fab1d3c047e932272f5349c5ba872b.pngimage.thumb.jpeg.3554be3a9f4340a730512df876930b42.jpeg
  • 3 weeks later...
  On 4/23/2021 at 12:04 AM, sdflysurf said:
Anyone else have one?  I want to throw a switch into my panel and replace the old mechanical pilot cut-off valve with the electric vacuum solenoid valve.
Expand
while so not legal, 12v solenoid valves are dime a dozen.  https://www.digikey.com/en/products/filter/pneumatics-hydraulics/809?s=N4IgTCBcDaIM4HsA2BTAdgglgEwAQDcBDJfFEAXQF8g
  On 4/24/2021 at 2:01 PM, Yetti said:
Expand
yeah this is what I want to do.  12v switch in the panel - controlling a valve solenoid.  The tubing (Items 7 and 30 in the figure 32 above) looks to be 1/4" Inside diameter - so I looked and I found one that says "1/4inch DC 12V 2 Way Normally Closed Electric Solenoid Air Valve"
https://www.amazon.com/dp/B084YTNG2P/ref=cm_sw_em_r_mt_dp_RXS8TB5KGGFZTNE2QH2F
it uses NPT 1/4" threaded connectors - do you know what NPT connector I would need to "mate" with the 1/4" tubing I have? (I'm not a plumber and I don't know tubes/pipes/line)
EDIT: I think I found a connector - would this do the trick? https://www.amazon.com/dp/B07NB6VZF7/ref=cm_sw_em_r_mt_dp_T4PQDYK92DMJXHJC7439?_encoding=UTF8&psc=1
This is the tube I have - I looked it up and it said 1/4" Inside Diameter:IMG_6122.thumb.JPG.e8d6c7ae0c621fd1c0fa1332af4e71f0.JPG
sdf,
Sounds like it may be a good time to work with your mechanic...
The NPT often uses Teflon tape, or thread dope... national pipe thread... (conic in shape)
Something you probably don’t want to have accidentally enter your vacuum system...
Or look for a better type of connection... one that uses compression fittings... or whatever the rest of vac system uses...
PP thoughts only, not written very well, but hoping to get that Teflon tape point across...
  On 4/24/2021 at 4:23 PM, carusoam said:
sdf,
Expand
yeah that makes sense.  Sounds like I need to find a part that has the nipple built onto it that my tubing slides onto and then I do a hose clamp like my current setup. THX.
