I checked with the Lycoming distributor unable to get new Tappets at this time. Hydraulic units are back ordered causing tappets to be unavailable. Does anyone know where the DLC coated IO 360 A1A Tappets can be purchased at this time?
Spruce is a distributor too. But I would google the part # and see if you might find someone with them in their inventory - if you need them now. But given engine rebuilds takes months, if its a few weeks wait or even a month, that's not uncommon right now.
Assuming I don’t run into other parts sourcing problems this overhaul won’t take months.  I will see what I can find in the Spruce catalog.  Thanks!
I was told by couple of shops that OH are taking so long (up to 15-16 weeks) due to lack of parts. So depending what you need, it might take longer then expected.
Thanks Igor.  From my sourcing efforts I can believe that.  I think my hold up is going to be inspection and machining of the crankshaft, but 5here may very well be other parts that come up delayed.
Our local engine shop reports the same issue with parts supply.  I wonder if Lycoming and Continental are choking out the competition.
