anthonydesmet Posted March 3, 2021 Report Share Posted March 3, 2021 Looking for possible salvage suggestions or if someone has a door and faring laying around.....1980 M20K....I have always had an issue with the top section of my RH middle gear fairing. The fiber glass keeps getting frayed due to the main gear door not coming down all the way to make a perfect overlap of the metal door over the fiberglass fairing. It looks like at one time the previous owner grinded a section out of the aft lower part of the main gear door so instead of having a strait edge going from front to back on the lower metal main gear door it rises up leaving a gap between main gear door and middle gear fairing when the gear is raised resulting in the upper part of the middle fiberglass fairing being exposed....thus fraying due to the air moving across and behind the fiberglass. If I am looking at my IPC correctly part numbers should be: RH Main Gear Door: 550065-004 RH Gear Middle Fairing: 550089-902 (although there are several other sn's) But for now, MLG Door is probably all I want since I can repair the fairing. Quote Link to comment Share on other sites More sharing options...
anthonydesmet Posted March 3, 2021 Author Report Share Posted March 3, 2021 Hard to see the Main door here but when you look at my fairing at the top that's coming a part...that's about where the main door (does not overlap) was grinded and starts to rise up vice having a long strait edge. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 3, 2021 Report Share Posted March 3, 2021 I would just get a piece of sheet metal, cut it out to match the gear door. Drill out all the rivets, cleco the two pieces together, and match drill the new piece, then rivet it all back together. A nice afternoon project. You will have to find someone with a brake to put the crease in the front. Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 4, 2021 Report Share Posted March 4, 2021 For Mooney salvage press one... For pre-flown parts press two... @Alan Fox @Jerry Pressley @SheryLoewen Quote Link to comment Share on other sites More sharing options...
J Bird Posted March 5, 2021 Report Share Posted March 5, 2021 Just bought this same part from Paul Loewen for my M20K 252 a month ago and had a great experience, quick shipping from CA to MA. 1 Quote Link to comment Share on other sites More sharing options...
