Hello, I’m replacing some very old circuit breakers that are causing voltage drop between my alternator and my main bus.  Unfortunately I can’t see a modern equivalent part number for the 70 amp alternator circuit breaker in the maintenance manual.  The breaker itself looks like this (MS39065-3).
I’d also like to have the 50amp aux bus breaker on hand.  It looks like a standard klixon, but I can’t quite see the part number?
2 hours ago, EricJ said:
The top one appears to be a PDLM-70.
Ahh, thanks.  PDLM seems to be the magic letters I couldn’t find.  That comes up easily on Spruce.  Now if it wasn’t $220, that would be terrific!
Thanks for the help!
The other one is either a Tyco or Klixon 50 amp.  One is $22, one is $184.  I’m just not lucky enough for it to be the $22.
1 hour ago, Yetti said:
The -3 usually means 3 amp.
Not is this case.  MS39065 is a long cancelled MIL spec.  The -3 denotes 70 Amp:
Edited by MikeOH
Nice, where’d you find that?  That’s it for sure, but I think the new part is the PDLM that @EricJ said.
Very useful site for military specs, both old and current: https://quicksearch.dla.mil/qsSearch.aspx
In the case of this part it gets even worse, the suggested spec, MIL-C-13516/4 was also cancelled!  In that spec, you will find that there is not a subsequent MIL spec, but a reference to a CID(Commercial item description), AA55571/04-004 , of which PDLM-70 is, I believe, conforming (but, you'd need to verify that part's specifications to the CID number to be certain.  (Sorry, I'm too lazy to track that down!)
Edited by MikeOH
Sometimes can maybe or not
You said, "usually means" And, I said, "Not in this case"
What are you getting at with this post????
Working on my appropriate disclaimer or maybe should have added when working with Potter Brumfield or Klixon
