moontownMooney Posted December 5, 2020 Report Posted December 5, 2020 Anyone have any advice (pros and cons, recommendations, beware of's) regarding the different instrument bezel lighting options? We are looking to redo our panel and incorporate bezel instrument lights in the process. I've seen the Nulite, UMA, and fiberlite options. I believe all three of these are approved for certified aircraft. Nulites use traditional lighting, UMA requires a DC to AC converter, and Fiberlite use fiberoptics and LEDs. I think I'm iinclined to go with the Nulites, to avoid the converters and fiberoptics (extra boxes to find a spot for and slightly more complicated wiring), but I suspect there are considerations im missing. Thanks for your help! Sent from my LM-V405 using Tapatalk Quote
Hank Posted December 5, 2020 Report Posted December 5, 2020 I'm satisified with my NuLites. Even added a few more. Quote
jamesm Posted December 6, 2020 Report Posted December 6, 2020 (edited) With the nu-lites depending on your panel spacing may require modification to the nulite bezel in order for the instrument to fit vertically / horizontally. Kind of pita trying to hold the instrument and trying feed the panel screw through nulite to the instrument.. The other thing is on the nu-lites it places the VSI is too far back for me to adjust the offset to zero the VSI I use to use a corner of the credit card to adjust it but doesn't fit any more. I guess need to make a screw adjusting tweaker to fit the hole. I have only flown a couple times after installing them. Much better than about the shoulder Red torpedo lights. I maybe me but the nu-lites seem to illuminate about 2/3 upper half of the instrument face is still readable but just an observation. James '67C Edited December 6, 2020 by jamesm Quote
carusoam Posted December 6, 2020 Report Posted December 6, 2020 Some CB options to get started... New LEDs for the over head lights pointed at the IP... LED post lights are an easy update... PP thoughts only... Best regards, -a- Quote
