I’m putting this here because a j model might be the same as my F
Does anyone know the location of the transistor panel in a 75F?
Similarly does anyone know if the 5a fuse off the circuit breaker panel (flaps/autopilot/gauges row) is collocated or remote?
It's on top of the nose wheel well.
Held on with 4 screws and 2 adel clamps.
There are three fuses on the transistor panel with these plug in fuses
https://www.alliedelec.com/product/littelfuse/37011000410/70184438/?gclid=CjwKCAiA1rPyBRAREiwA1UIy8B5HSZbdXFH3Y3ElfyKiNElyBO49IzJyLxVcVpSZ_Txu_-WIpi2E5RoC2PQQAvD_BwE&gclsrc=aw.ds
They are fed via the 2 CB called Inst.  Lts  middle row.
Edited by Yetti
5 hours ago, Cyril Gibb said:
Thanks guys.  Replaced a bad fuse on the transistor panel. It works :D
now to find the fuse behind the breaker panel
There are two one on either side of the shunt mounted on the firewall.   Handy to wire in a ampmeter for fancy panel.   Took them apart and soldered the wires into the ends that sit on the fuses.  copilot side middle of the access panel  burried under the wiring harness.   Got lucky and worked the first time.   Also put the voltmeter wire there.
