CaptRJM Posted August 1, 2019 Report Posted August 1, 2019 My trusty KX165 has suddenly started acting up. It will not receive VOR or Localizer and Glide slope is consistently reading low. We know it is certainly the radio as I swapped in a known good one and it works fine .... so, the problem is certainly the radio, not the installation. Any recommendations who to send it to for fairly priced service? Yes, I know I should look at a replacement but not in the budget right now. Quote
Guitarmaster Posted August 1, 2019 Report Posted August 1, 2019 I would try Avionics Place in KRFD. They are very good.Sent from my Pixel 2 XL using Tapatalk Quote
KSMooniac Posted August 1, 2019 Report Posted August 1, 2019 Bevan in WichitaSent from my LG-US996 using Tapatalk Quote
steingar Posted August 1, 2019 Report Posted August 1, 2019 Mayday in Michigan does this sort of thing as well. Quote
vorlon1 Posted August 1, 2019 Report Posted August 1, 2019 4 hours ago, CaptRJM said: My trusty KX165 has suddenly started acting up. It will not receive VOR or Localizer and Glide slope is consistently reading low. We know it is certainly the radio as I swapped in a known good one and it works fine .... so, the problem is certainly the radio, not the installation. Any recommendations who to send it to for fairly priced service? Yes, I know I should look at a replacement but not in the budget right now. Not that the above is the case, but I understood that 155's and 165's displays could no longer be repaired for lack of parts. Can one of the shops listed here repair them? Quote
neilpilot Posted August 1, 2019 Report Posted August 1, 2019 2 hours ago, vorlon1 said: Not that the above is the case, but I understood that 155's and 165's displays could no longer be repaired for lack of parts. Can one of the shops listed here repair them? Bad displays are replaced, not repaired. The OEM gas discharge display is no longer available. However, BK does sell an upgraded led display. 1 Quote
PT20J Posted August 2, 2019 Report Posted August 2, 2019 Be sitting down when you call. It’s pretty pricey. Quote
Jerry 5TJ Posted August 2, 2019 Report Posted August 2, 2019 About $3,000 for Honeywell to refurbish your KX165 including installation of a new display and alignment to as-new specifications. Quote
moontownMooney Posted August 4, 2019 Report Posted August 4, 2019 Bevan Rabell! I'm packing up some legacy BK avionics to send their way as we speak. Also, for the folks discussing displays... different symptoms are caused by different things: Display suddenly goes out entirely = likely high voltage module failure (Sent from my LM-V405 using Tapatalk Quote
seaero Posted August 13, 2019 Report Posted August 13, 2019 Here is a link for the authorized Repair Partners for BendixKing: https://www.bendixking.com/en/pages/repair-partners Quote
CaptRJM Posted August 13, 2019 Author Report Posted August 13, 2019 Thanks to everyone. Sent it off to Bevan. Waiting to hear back from them. Quote
