Marauder Posted April 12, 2019 Report Posted April 12, 2019 Exercising my right under Part 43, I noticed during my oil change the quick drain on my engine looks like it might have begun seeping a little. Two questions: 1) For the IAs, am I allowed under Part 43 to replace the quick drain with another one? If I didn’t have a quick drain, I would be removing a plug. Is replacing the quick drain like installing the plug? 2) I have an IO-360 A1A, is this the correct replacement quick drain? https://www.mcfarlaneaviation.com/products/product/A5020/ And is it the same has the one on Aircraft Spruce? https://www.aircraftspruce.com/catalog/eppages/safOilDrainValves.php?clickkey=6418 (And if it is, how do they get away with an almost 100% mark up?) Sent from my iPad using Tapatalk Pro Quote
orionflt Posted April 12, 2019 Report Posted April 12, 2019 Question 1, yes you can Question 2 it is Question 2B it's a certified aviation part best thing to do is to pull your current drain and just replace the oring Quote
orionflt Posted April 12, 2019 Report Posted April 12, 2019 What is the o ring replacement number for the P5000? 2 each of AN6227B-6 and 1 each of AN6227B-7 are the replacement o-rings for the valve. Quote
orionflt Posted April 12, 2019 Report Posted April 12, 2019 here is the o ring for the aeroquip valve: Valve O-Ring, All Models MS28775-011 Quote
Marauder Posted April 12, 2019 Author Report Posted April 12, 2019 What is the o ring replacement number for the P5000? 2 each of AN6227B-6 and 1 each of AN6227B-7 are the replacement o-rings for the valve. I don’t think it is leaking from the O ring. I have never seen this type of drain before. I can see an actual spring and it looks to be leaking internally and coming out the end of the drain, not around the base. I’m headed over to the airport soon and will snap a picture of the little bugger. Sent from my iPad using Tapatalk Pro Quote
orionflt Posted April 12, 2019 Report Posted April 12, 2019 5 minutes ago, Marauder said: I don’t think it is leaking from the O ring. I have never seen this type of drain before. I can see an actual spring and it looks to be leaking internally and coming out the end of the drain, not around the base. I’m headed over to the airport soon and will snap a picture of the little bugger. Sent from my iPad using Tapatalk Pro there is an internal o ring, that is what is probably leaking those were the different numbers i gave you. the base gasket is a copper crush gasket. Quote
Marauder Posted April 12, 2019 Author Report Posted April 12, 2019 Mine looks absolutely nothing like this. Maybe the internal mechanism is the same but it doesn’t look like it from the outside.Sent from my iPad using Tapatalk Pro Quote
Marauder Posted April 12, 2019 Author Report Posted April 12, 2019 there is an internal o ring, that is what is probably leaking those were the different numbers i gave you. the base gasket is a copper crush gasket. Ok Brian. What is it?Sent from my iPhone using Tapatalk Pro Quote
orionflt Posted April 12, 2019 Report Posted April 12, 2019 thats one of the first drain valves approved, i believe it was aeroquip but not sure. either way the design is the same. Quote
MB65E Posted April 12, 2019 Report Posted April 12, 2019 That’s the Curtis CCB-37000. Aircraft spruce when I ordered mine says it’s not PMA’d for oil use. However, I called the MFG directly and they gave me the data I needed to install it. I’m not sure if spruce has since updated their data. Use some heat and patients getting the old one off. -Matt 1 Quote
Marauder Posted April 13, 2019 Author Report Posted April 13, 2019 That’s the Curtis CCB-37000.Aircraft spruce when I ordered mine says it’s not PMA’d for oil use.However, I called the MFG directly and they gave me the data I needed to install it. I’m not sure if spruce has since updated their data.Use some heat and patients getting the old one off. -Matt Thanks Matt. It’s been on there a long time and doesn’t owe me anything. Hopefully it comes off easily. Sent from my iPad using Tapatalk Pro Quote
Yetti Posted April 13, 2019 Report Posted April 13, 2019 4 hours ago, Marauder said: Ok Brian. What is it? Sent from my iPhone using Tapatalk Pro Had the same one on mine. Could not figure out what it was. Believe those are 3/4" pipe threads. I wondered if I could replace it. Then I wondered if it was not there, could I remove and replace a pipe plug to drain the oil. Heat gun and permetex. Stand by and I will get a spruce number 1 Quote
Yetti Posted April 13, 2019 Report Posted April 13, 2019 P5000 1/2 NPT (National Pipe thread) gonna need a heat gun to get it loose. P5000 Lyc. (same as Aeroquip AE80664H) 1/2 NPT 07-00879 $92.5 1 Quote
Marauder Posted April 13, 2019 Author Report Posted April 13, 2019 Thanks. Any advantage of going with one brand over another? The Aeroquip version that is cross referenced is a lot more expensive that the one you posted. Do you know if any have a better track record than another?Sent from my iPad using Tapatalk Pro Quote
Yetti Posted April 13, 2019 Report Posted April 13, 2019 It's a way smaller hole than what you have on there so it takes longer for the oil to drain. One day I will pull the original apart and replace the O rings so it is ready to go when the current one fails. It has one job. Not leak. It does that well. 1 Quote
eman1200 Posted April 13, 2019 Report Posted April 13, 2019 5 hours ago, Marauder said: Ok Brian. What is it? Sent from my iPhone using Tapatalk Pro I have this one as well 1 Quote
RLCarter Posted April 13, 2019 Report Posted April 13, 2019 5 hours ago, Marauder said: Ok Brian. What is it? Yep, same ugly POS on the Mooney right down to the 90, the 172 has the same one less the 90 plus something similar to this, just held on with a zip tie Quote
MB65E Posted April 13, 2019 Report Posted April 13, 2019 The 37000 will last longer and flow better than the P5000 will. I’ve worked with both. The 37000 is Stone Age in a good way. -Matt Quote
carusoam Posted April 14, 2019 Report Posted April 14, 2019 On 4/12/2019 at 9:03 PM, Marauder said: Thanks Matt. It’s been on there a long time and doesn’t owe me anything. Hopefully it comes off easily. Sent from my iPad using Tapatalk Pro My 65C had one that looked just like it... but always had a drip of oil hanging from it... It didn’t have the honor of the piece of safety wire hanging on the spring release either... Now we know how easy it is to dump all the oil out the drain... So many newer designs for that. Swapping it out will make you feel better.... Best regards, -a- 1 Quote
N201MKTurbo Posted April 14, 2019 Report Posted April 14, 2019 It looks like your lock wire may be biasing center of the valve. This could be affecting the o ring seating. You may want to take it off and see if it stops leaking. If you are going to replace it go with the Curtis. They are made here in Chandler AZ! 1 Quote
mike_elliott Posted April 14, 2019 Report Posted April 14, 2019 On 4/12/2019 at 9:03 PM, Marauder said: Hopefully it comes off easily. heat plus 6 pt deepwell. I have a new quickdrain for an IO360 somewhere in the garage I am not/wont be using...Ill ping you if I turn it up today. When I had a hangar, I knew right where everything was! Mike 1 Quote
