rbridges Posted April 10, 2019 Report Posted April 10, 2019 Just wondering what the cost of adding it to the Aspen is. Does it allow you to fly /G in the event of primary GPS failure? Quote
DXB Posted April 10, 2019 Report Posted April 10, 2019 8 minutes ago, rbridges said: Just wondering what the cost of adding it to the Aspen is. Does it allow you to fly /G in the event of primary GPS failure? I didn't realize it was an option - it's standard on the PFD and MFD 1000 installs, just absent on the MFD 500. Someone correct me if I'm wrong. If it can still get way points from the failed panel GPS receiver, it should work for emergency navigation I would think? I don't think it's a WAAS receiver though. 1 Quote
LANCECASPER Posted April 10, 2019 Report Posted April 10, 2019 34 minutes ago, rbridges said: Just wondering what the cost of adding it to the Aspen is. Does it allow you to fly /G in the event of primary GPS failure? As was mentioned, the PFD1000 and MFD 1000 have it, but it is backup (emergency) and does not allow you to file /G without your primary IFR approved GPS. 1 Quote
rbridges Posted April 10, 2019 Author Report Posted April 10, 2019 5 minutes ago, DXB said: I didn't realize it was an option - it's standard on the PFD and MFD 1000 installs, just absent on the MFD 500. Someone correct me if I'm wrong. If it can still get way points from the failed panel GPS receiver, it should work for emergency navigation I would think? I don't think it's a WAAS receiver though. I don't believe I have the antenna for the RMS. I have the two antennas for the PFD and MFD. I was just reading through the manual and saw the reference to the RMS GPS. Quote
LANCECASPER Posted April 10, 2019 Report Posted April 10, 2019 4 minutes ago, rbridges said: I don't have the antenna for the RMS. I have the two antennas for the PFD and MFD. I was just reading through the manual and saw the reference to the RMS GPS. Built into the RMS (Remote Sensor Unit) is the GPS antenna. 2 Quote
DXB Posted April 10, 2019 Report Posted April 10, 2019 1 minute ago, rbridges said: I don't have the antenna for the RMS. I have the two antennas for the PFD and MFD. I was just reading through the manual and saw the reference to the RMS GPS. The GPS receiver is part of that sameantenna I think? No separate one. If you turn on your Aspen but not your panel GPS, the Aspen should annunciate RSM reversion at the bottom. 1 Quote
rbridges Posted April 10, 2019 Author Report Posted April 10, 2019 Thanks. I'll check it out. I took it that it was separate. Quote
rbridges Posted April 17, 2019 Author Report Posted April 17, 2019 On 4/9/2019 at 10:23 PM, LANCECASPER said: As was mentioned, the PFD1000 and MFD 1000 have it, but it is backup (emergency) and does not allow you to file /G without your primary IFR approved GPS. I was fiddling with it tonight. When I killed my 430, the MFD GPS display froze. The menu did not allow me to switch to another GPS source. I looked at the aspen website, and it says that the backup GPS is optional. Is it just available on the MFD 1000 and has to be unlocked? Quote
Marauder Posted April 17, 2019 Report Posted April 17, 2019 I was fiddling with it tonight. When I killed my 430, the MFD GPS display froze. The menu did not allow me to switch to another GPS source. I looked at the aspen website, and it says that the backup GPS is optional. Is it just available on the MFD 1000 and has to be unlocked? The backup GPS is standard on the Aspen PFD and an option on the MFD. The backup GPS only comes into play if your panel mounted GPS fails with an ACTIVE flight plan loaded in it and has already transmitted to the Aspen. Once it is in the Aspen, the flight plan will show up on your PFD and the heading to each of the waypoints will display as if your panel mounted GPS was still active. You cannot change it but you can navigate with it. If you have a MFD 1000, you can port over the GPS function and flight plan through the reversion function. Sent from my iPad using Tapatalk Pro 1 Quote
Marauder Posted April 17, 2019 Report Posted April 17, 2019 And BTW, if you didn’t purchase the MFD backup GPS, your MFD RSM will contain only the AHRS, OAT probe and magnetometer. Sent from my iPad using Tapatalk Pro Quote
