I recall ferrite filters in the equation.
The G4 includes a ferrite filter. It appears to be installed correctly.
Spent about 45 minutes on the phone with Insight today. Learned a bunch about the monitor and some direction to try.
Chris@Marauder , you had a similar problem?
Sent from my Pixel 2 XL using Tapatalk
[mention=9886]Marauder[/mention] Matt guitar Murphy  is looking for you...   ^^^^
He said I was shunned because I have two engines now....
Shunned... that’s the first stage of transitioning away from Speed and efficiency...
Two engines... that is twice the challenge for engine monitors...
Marauder likes BiG challenges... big electrical, technical, challenges...
Marauder needs to be convinced/coerced that fixing this issue could be good for him...
Thinking about this for a moment... how much payload can that twin handle?
quick, put the dark glasses on in case things go awry....   B)
With full fuel, I got room for 1000lb of peeps and baggage . Now, when it's time to fill up..... .
