toto Posted January 7, 2019 Report Posted January 7, 2019 My 20-year-old paint is in great shape for the most part, but it has started to develop a handful of small chips right on rivet heads. I want to prevent these small chips from growing - what's the best way to do that? I'm afraid that regular old touch-up paint is mostly cosmetic, and won't add much integrity to the surrounding paint (but I'm happy to be told otherwise).
Supercop0184 Posted January 7, 2019 Report Posted January 7, 2019 Following Sent from my iPhone using Tapatalk
RLCarter Posted January 7, 2019 Report Posted January 7, 2019 53 minutes ago, toto said: I'm afraid that regular old touch-up paint is mostly cosmetic kind of, if the damaged area is properly prepared back to good paint, touching it up is no different, just a smaller area. I would use an AirBrush, when masking off roll the tape edge up to help eliminate a "HARD" line
milotron Posted January 7, 2019 Report Posted January 7, 2019 2 minutes ago, RLCarter said: kind of, if the damaged area is properly prepared back to good paint, touching it up is no different, just a smaller area. I would use an AirBrush, when masking off roll the tape edge up to help eliminate a "HARD" line Would you use a primer? Does the paint need to be compatible with the existing top coat? I do like the airbrush idea, I need to do this on my plane also. iain
RLCarter Posted January 7, 2019 Report Posted January 7, 2019 14 minutes ago, milotron said: Would you use a primer? yes, most paints don't stick to aluminum (very long). It's the same process as painting just a much smaller area
PT20J Posted January 7, 2019 Report Posted January 7, 2019 It’s really hard to blend new paint into the old without it showing. Airbrushing isn’t a bad idea for larger areas but may make a little chip like this more visible. Take the tail access panel to an auto paint store and get a color match. Clean area with solvent, then use a small brush to apply a self etching primer like SEM and then a couple of color costs to fill in. 2
Andy95W Posted January 7, 2019 Report Posted January 7, 2019 9 hours ago, PT20J said: It’s really hard to blend new paint into the old without it showing. Airbrushing isn’t a bad idea for larger areas but may make a little chip like this more visible. Take the tail access panel to an auto paint store and get a color match. Clean area with solvent, then use a small brush to apply a self etching primer like SEM and then a couple of color costs to fill in. +1 Short of repainting an entire panel on the airplane, this is the only method I've ever seen that works decently well. And it isn't perfect- after multiple daubs of paint, it can be wet sanded to look good from about 5 feet away, but still not perfect.
toto Posted January 8, 2019 Author Report Posted January 8, 2019 43 minutes ago, GEE-BEE said: Eyedropper if you need one let me know I will post DBM who installs new windows uses eye dropper for touch up also. We include with our silicone cement in our chafecseal kit for the catalyst on our clear silicone cement. Sure, please post. I have no idea what the eyedropper application looks like.
