Any suggestions for a good set of pliers that will last?  I have a pair now, but they do a lousy job of cutting twisted wire. Thanks in advance.
Just avoid the cheap Chinese ones, mine lasted about six oil changes (the only safety wire they ever twisted or cut).
Back in the 1960s, I bought a used pair of safety wire pliers at a surplus aircraft supply in Tulsa OK, presumably because they were no longer serviceable for use in the aircraft industry.  The judicious use of a center punch on the center pivot post tightened them up, and re-bucking the rivets holding the twister device in place, improved them. Admittedly I do not use them a whole lot, but I still prefer them to a new pair I bought 5 or 6 years ago.
I don't remember what I paid for them, but I doubt it was over $5.
For the little bit of safety wiring the average owner needs to do, I’d suggest a duckbill pliers and a side cutter.
That would be painful for my oil filter, where it needs to be about 5" between filter and attach point.
Get the standard one direction Milbar’s.  Even milbar reversing pairs always fail. I’ve been thru two of them in 18 years.  Some of the older MFG’s are really great and buttery smooth if you can find good used set on eBay from an old tech
-Matt
-Matt
I got mine back in the early 80's, they were used when I got them and still going strong
