6 hours ago, cliffy said:
Top of cowl vents = windshield anti-ice system.  :-) :-)
Also = windshield oil system, if you ever have a problem.
3 hours ago, 1964-M20E said:
that is to keep the ice form sticking.  :lol:
Then what am I going to do with all the WD-40 I bought?;)
On 7/6/2018 at 9:46 AM, MyNameIsNobody said:
Literally said in first sentence a 4-6 knot speed increase with cowl...
I believe he meant after the ducts were installed, performance difference before and after duct installation.
Maybe not though?
df
Maybe not though?
df
In addition to the side vents, I know they are planning on widening the inlets a bit as well. I’m sure Matt will update us to the new TAS once they have it dialed in.
On 7/15/2018 at 12:28 AM, Mooneymuscle56m said:
Mechanics I’ve spoken with prefer to work on an acclaim, I guess the bravo has a lot attached to the cowling
A couple of ducts that come off easily with cam locs. Add 10 minutes tops to R and R. You must speak to well pampered mechanics
Maybe not though?
df
Ahhhhh, O.K. My bad.
  • 2 weeks later...
I spoke to Matt yesterday through texts. David and his schedule haven’t allowed them to do the next step which was to widen the inlets a bit.
I flew a short flight today after completely replacing the baffle seals with much heavier rubber. I appear to have excellent sealing all around. The CHTs are fine, one cyl slightly over 360 at its hottest, the rest from 330 to 350+,  the OTemp is better but not great. 215-220F on a day that was 92F on the ground and 79F at 3500'. I suppose that the ambient makes more difference with OT than with CHTs since the delta T is much lower %age wise.
Did you buy a kit or free hand it?
Bob and @Sabremech
I really like the cooling I currently enjoy.  This is what I get normally on a 90 degree day on my way to Madison for the Caravan (on number 4 to boot).  .  This year, I have had only one instance of CHTs even approaching 360.
Note - The defective EGT probe on number 2 is being replaced this week.
5 hours ago, Bob_Belville said:
...with much heavier rubber...
What material specifically? Spruce? Lowes? McFarland?
I frankly think this may be my problem, the silicone stuff is just too 'floppy'.
<<cue the cockpit humor>>
It was something that Lynn had on hand, I don't find it on Spruce though I think it should have come from there. It is fiberglass reinforced and is not slick.
Looking forward to hearing about all these updates live at Mooney Summit!
Airport day is open to everyone registered, wait list, or those who just feel like dropping in.
-Seth
The textured material on the sides looks like material from Browns Aircraft Supply.
