Yetti Posted June 8, 2018 Report Posted June 8, 2018 You also might want to check the rear most seat holes to see if they don't have crud in them. A .1/4" drill bit spun by hand should clean them out.
Yetti Posted June 8, 2018 Report Posted June 8, 2018 Also there should be a pin somewhere along the back of the seat rails. Some people use a hitch pin or you could use a cotter pin. Keep the seat from sliding all the way back should it release.
Seymour Posted June 8, 2018 Report Posted June 8, 2018 Lance, thank you for posting your experience. Constant reminders against complacency are helpful. Very happy you kept it under control (and that it didn't occur on a go-around). ...and could that be the OP's actual issue? A previous owner had Lance's experience so placed a cotter pin in a position on the rails so that the seat would never slide to the farthest position?
Igor_U Posted June 8, 2018 Report Posted June 8, 2018 On my '67F, cotter pin hole is some 2" aft of the last seat pin hole on the rail. I'm 6'4" and comfortably use the last hole for take off/landing but often slide to the stop (cotterpin) on long flights when I don't need rudder. it gives me more room from the panel/yoke and better instrument scan. 1
Marauder Posted June 8, 2018 Report Posted June 8, 2018 Also there should be a pin somewhere along the back of the seat rails. Some people use a hitch pin or you could use a cotter pin. Keep the seat from sliding all the way back should it release. I have used hitch pins in the past and every time the MSC removes them, puts them in a baggie and installs cotter pins. Are cotter pins the required hardware? They are such a PITA to remove if I want to remove the seats quickly. Sent from my iPhone using Tapatalk Pro
Bob_Belville Posted June 8, 2018 Report Posted June 8, 2018 I use a clevis pin and clip. Surely more elegant that a cotter pin. https://www.zoro.com/zoro-select-clevis-pin-std-zinc-0187x1-l-pk10-p11-011z/i/G3371137/feature-product?gclid=EAIaIQobChMI--6-6ZDE2wIVlTqBCh09vgL3EAQYBCABEgIVzPD_BwE 2
Marauder Posted June 8, 2018 Report Posted June 8, 2018 I use a hitch pin and clip. Surely more elegant that a cotter pin.https://www.zoro.com/zoro-select-clevis-pin-std-zinc-0187x1-l-pk10-p11-011z/i/G3371137/feature-product?gclid=EAIaIQobChMI--6-6ZDE2wIVlTqBCh09vgL3EAQYBCABEgIVzPD_BwE So if I use a clevis pin they won’t changed it back to a cotter pin?Sent from my iPhone using Tapatalk Pro
Bob_Belville Posted June 8, 2018 Report Posted June 8, 2018 10 minutes ago, Marauder said: So if I use a clevis pin they won’t changed it back to a cotter pin? Sent from my iPhone using Tapatalk Pro Are you on speaking terms with your shop? Ask them! In my case, Lynn does not r&r my seats and probably doesn't know what I'm using.
Marauder Posted June 8, 2018 Report Posted June 8, 2018 Are you on speaking terms with your shop? Ask them! In my case, Lynn does not r&r my seats and probably doesn't know what I'm using. I’ll ask them next time. I think my seats have been removed on annuals to pull the side panels to look at the structure. Sent from my iPhone using Tapatalk Pro
Hank Posted June 8, 2018 Report Posted June 8, 2018 3 hours ago, Marauder said: I have used hitch pins in the past and every time the MSC removes them, puts them in a baggie and installs cotter pins. Are cotter pins the required hardware? They are such a PITA to remove if I want to remove the seats quickly. Sent from my iPhone using Tapatalk Pro What's a hitch pin???
Marauder Posted June 8, 2018 Report Posted June 8, 2018 1 minute ago, Hank said: What's a hitch pin???
Hank Posted June 8, 2018 Report Posted June 8, 2018 5 minutes ago, Marauder said: Yeah, I like those, but I'm used to the ring on the end being round. And no strap to the cotter pin. They work great. Not sure what's on my seats, they don't come out very often.
Marauder Posted June 8, 2018 Report Posted June 8, 2018 Just now, Hank said: Yeah, I like those, but I'm used to the ring on the end being round. And no strap to the cotter pin. They work great. Not sure what's on my seats, they don't come out very often. I had these in the plane and they were removed by the MSC and replaced by cotter pins. Personally, I think they are much stronger than cotter pins but they must have a reason.
thinwing Posted June 8, 2018 Report Posted June 8, 2018 3 hours ago, Marauder said: I had these in the plane and they were removed by the MSC and replaced by cotter pins. Personally, I think they are much stronger than cotter pins but they must have a reason. The cotter pins are what the factory used and are probably specified on the TC.No matter that the hinch pins are stronger and a huge improvement...there use would require an STC and complete flight testing before Flight Standards would approve them
ziggysanchez Posted June 8, 2018 Report Posted June 8, 2018 On 6/4/2018 at 11:52 PM, mwilton1 said: Thanks Guys. I actually need the space between my right knee and the center console, but the rudder extensions might help a little. I spoke to my mechanics about drilling a couple new holes. They said it would take an engineering drawing and approval....or a night in the hanger with a tape measure, drill bit and careful measuring. Looks like that might be my option. The plane is perfect other than that, so if we could get that sorted I am all set. Thank you for the quick responses, great community here I have a 1980 K model and know exactly what you're talking about. I'm 6'3" and need just a little more room when locked in the last holes. My right knee digs into the cabin air vent knob. I usually takeoff, fly and land with the seat in the full back position when by myself. When I have a passenger behind me it can be rather uncomfortable for my knee if I have to stay in that forward position for a long period of time.
Bartman Posted June 10, 2018 Report Posted June 10, 2018 While I had my interior and seats out this past week I took the opportunity to clean the holes int the seat rail with a screwdriver and shop vac. Although I have never had a problem as you described, I did remove a significant amount of dirt and debris and it was packed in there...40 yeas worth. 1
chrisk Posted June 10, 2018 Report Posted June 10, 2018 I have a 1981 M20K. I'm 5'11. I think I am pretty close to the front most hole. If anyone has 3" extensions they are removing, please let me know. As I have aged, I now appreciate sitting a bit further back from the panel.
mwilton1 Posted June 10, 2018 Author Report Posted June 10, 2018 So did a bit of messing around with the plane today. Changed the cam adjuster on the seat back and had a little more room for the yoke. Will have to change it in flight and see how it feels, as this was just in the hanger. Will keep you posted. Mike
OR75 Posted June 10, 2018 Report Posted June 10, 2018 I d just say that I am happy Mooneys did not have the Cessna saga AD for seat rails and a seat belt to ho,d the seat
carusoam Posted June 10, 2018 Report Posted June 10, 2018 MWilton, Do you have the three position cams that goes from vertical to 10° Or 20° And too far back? There is a whole thread for checking for unusual wear of the aluminum part and possibly how to find a modern replacement for the Cam... The seat cam part was ingenious in the early 60s... but had a tendency to wear out over a few decades or so. Just something that may be helpful for you to look into. PP thoughts only, not a mechanic... Best regards, -a-
EricJ Posted June 12, 2018 Report Posted June 12, 2018 These are what's in my airplane. They're pretty easy to pop in and out and work well.
