Marty71112 Posted May 14, 2018 Report Posted May 14, 2018 Cross country from Louisiana to NC. Didn't secure gas cap on 1970 M20F. Safe landing minus left cap. Any ideas where to start looking for replacement? marty
LANCECASPER Posted May 14, 2018 Report Posted May 14, 2018 5 minutes ago, Marty71112 said: Cross country from Louisiana to NC. Didn't secure gas cap on 1970 M20F. Safe landing minus left cap. Any ideas where to start looking for replacement? marty Post the part number from the remaining one. Is it a Shaw?
carusoam Posted May 14, 2018 Report Posted May 14, 2018 Good news, Marty... You are not the first one to lose a cap... But, the price of new ones will be a reminder that you don’t want to do that again... Start with what part number you have on the other one... this will be helpful. Is it factory original? Or added later for fuel cell upgrades? The name of the manufacturer and model numbers is often referred to by a guy selling fluoro silicone o-rings... The most direct / proper way to order a replacement from Mooney is order through the MSC network. Lasar.com is pretty helpful... you could probably have one in a day or two... Now for the CB method... we have a guy.... we have two guys... @acpartswhse has a storage (or five) facility of parts with pre-tested histories.... Sanford may also have some in his collection... @Alan Fox PP thoughts only... I May know these guys, but it’s been a long few moths or days since i’ve Been in contact with them.... i haven’t met the OSU supplier yet. That phone call is on my list of things to do... Best regards, -a-
Marty71112 Posted May 14, 2018 Author Report Posted May 14, 2018 Actually son stuck on cross-country at M44 in Houston, MS. Sheriff will give him ride back to airport in AM and can get part number. Thanks for help! marty
carusoam Posted May 14, 2018 Report Posted May 14, 2018 Tough lesson to learn... It is always good to get the expensive leash that goes with them... And in the meantime... update the fueling procedures check list... Best regards, -a-
Piloto Posted May 14, 2018 Report Posted May 14, 2018 Because these caps are hard to get sometime they get lost on the ramp. José 1
Guest Posted May 14, 2018 Report Posted May 14, 2018 7 hours ago, Marty71112 said: Cross country from Louisiana to NC. Didn't secure gas cap on 1970 M20F. Safe landing minus left cap. Any ideas where to start looking for replacement? marty Have someone at your departure airport check the runway, it’s likely still there. Clarence
RLCarter Posted May 14, 2018 Report Posted May 14, 2018 5 minutes ago, M20Doc said: Have someone at your departure airport check the runway, it’s likely still there. Clarence Yep, just last week there was a J that lost their fuel cap, I had found them a loaner off a Queen Air but they walked the runway and found the original
Stephen Posted May 14, 2018 Report Posted May 14, 2018 8 hours ago, M20Doc said: Have someone at your departure airport check the runway, it’s likely still there. Clarence ...there is always the spiral walking search pattern starting from the takeoff end of the runway .... will need metal detector a big gardening hat and bug spray.
1964-M20E Posted May 14, 2018 Report Posted May 14, 2018 Which airport in Louisiana? I flew off with my left cap loose discovered it just sitting in the hole at 110 feet. Told ATC and spiraled down to the airport below me secure it properly. I was lucky it was still there. Before that occurred I found a spare one on eBay and it is in the plane. Yes I have the bladders so they are rare caps.
Seth Posted May 14, 2018 Report Posted May 14, 2018 Besides normal preflight when conducting your run up or at the hold shirt line add to your checklist look left and right to ensure fuel caps are secured. I look for that now. -Seth 1
Jim Peace Posted May 14, 2018 Report Posted May 14, 2018 1 hour ago, Marty71112 said: I have the same cap...I got them from one of the junk yards.....I forgot the names,,,maybe some others can chime in...I then sent it to the paint shop and they totally cleaned it up and painted it for my airplane. Just noticed a bunch on eBay for under 100 bucks,
Shiny moose Posted May 14, 2018 Report Posted May 14, 2018 I will check hanger I might have one of these, let me know if you find one
Sime Posted May 15, 2018 Report Posted May 15, 2018 (edited) My 76F has a chain from inside the fuel tank to the cap. Was that part of the 76's standard features, or would it have been added later on? Edited May 15, 2018 by Sime
carusoam Posted May 15, 2018 Report Posted May 15, 2018 Marty, are you still looking for a cap? @acpartswhse Jerry, Marty was looking for a fuel cap... part number in photo above.... Its been a day or two already... Best regards, -a-
mooniac15u Posted May 15, 2018 Report Posted May 15, 2018 13 hours ago, Sime said: My 76F has a chain from inside the fuel tank to the cap. Was that part of the 76's standard features, or would it have been added later on? I think you are supposed to remove that per AD 97-26-08. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/3663F2D3749FE48286256A8F006C5ED6?OpenDocument
moodychief Posted May 15, 2018 Report Posted May 15, 2018 Try Dawson's Aircraft Salvage in Clinton Arkansas. They had a couple of Mooney's they were parting out.
LANCECASPER Posted May 15, 2018 Report Posted May 15, 2018 6 hours ago, mooniac15u said: I think you are supposed to remove that per AD 97-26-08. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/3663F2D3749FE48286256A8F006C5ED6?OpenDocument This is the lanyard they went to after the chain: https://www.aircraftspruce.com/pages/ep/fuel_caps_zzaccessories/lanyardms27380-3.php
LANCECASPER Posted May 15, 2018 Report Posted May 15, 2018 It looks like the Shaw 431-9 caps are around $100 on Ebay. https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=shaw+fuel+cap+431-9&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=shaw+431-9
Guest Posted May 15, 2018 Report Posted May 15, 2018 1 hour ago, LANCECASPER said: This is the lanyard they went to after the chain: https://www.aircraftspruce.com/pages/ep/fuel_caps_zzaccessories/lanyardms27380-3.php The nylon version of the lanyard was to be removed by the AD mentioned above and by SB M20-259. Clarence
LANCECASPER Posted May 15, 2018 Report Posted May 15, 2018 2 minutes ago, M20Doc said: The nylon version of the lanyard was to be removed by the AD mentioned above and by SB M20-259. Clarence Thanks, I see that applies to F, J and L Mooneys.
Sime Posted May 16, 2018 Report Posted May 16, 2018 10 hours ago, mooniac15u said: I think you are supposed to remove that per AD 97-26-08. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/3663F2D3749FE48286256A8F006C5ED6?OpenDocument Appreciate the heads-up. I do not have a nylon lanyard in my F. Mine is a steel chain. I will check with the A&P, but I suspect that the AD had been addressed on my particular aircraft. Also, I have never experienced any erroneous fuel level readings. Lastly, I go by time intervals when I change tanks, the fuel usage I correlate with the fuel flow readings on my EDM700.
Guest Posted May 16, 2018 Report Posted May 16, 2018 (edited) 22 minutes ago, Sime said: Appreciate the heads-up. I do not have a nylon lanyard in my F. Mine is a steel chain. I will check with the A&P, but I suspect that the AD had been addressed on my particular aircraft. Also, I have never experienced any erroneous fuel level readings. Lastly, I go by time intervals when I change tanks, the fuel usage I correlate with the fuel flow readings on my EDM700. Per the AD the nylon lanyard is to be removed, there is no approval to install sometime different that I am aware of. Clarence Edited May 16, 2018 by M20Doc
Marauder Posted May 16, 2018 Report Posted May 16, 2018 Per the AD the nylon lanyard is to be removed, there is no approval to install sometime different that I am aware of. Clarence Mine originally had a metal chain on them. Sent from my iPhone using Tapatalk Pro
