flumag Posted May 6, 2018 Report Posted May 6, 2018 Hi, does anyone already have done a field approval for the Whelen ORION 650 E in an M20K? (the Whelen STC doesn't cover the M20K and also will not be enhanced in the foreseeable time) I'm just looking for some documentation to speed up the process. Thanks Hendrik Quote
ArtVandelay Posted May 6, 2018 Report Posted May 6, 2018 I think it can be installed as a minor modification, so only needs an AP signature. Talk to your mechanic. Quote
StevenL757 Posted May 6, 2018 Report Posted May 6, 2018 Exactly right. There is already approved data, so only a logbook entry is needed. My local shop on-field is doing an OR650E install on a J model now. Quote
PTK Posted May 6, 2018 Report Posted May 6, 2018 20 hours ago, flumag said: Hi, does anyone already have done a field approval for the Whelen ORION 650 E in an M20K? (the Whelen STC doesn't cover the M20K and also will not be enhanced in the foreseeable time) I'm just looking for some documentation to speed up the process. Thanks Hendrik Hendrik, you are substituting functionally similar TSO'd equipment. i.e. original ACL/NAV lights with new Orion 650E ACL/NAV lights. Both old and new are TSO’d and of similar functionality. Make a simple logbook entry and reference FAA AC 20-41A. That’s precisely the purpose and scope of this AC. You may also include a copy in the logbook. Here you go... https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_20-41A.pdf 2 Quote
KSMooniac Posted May 6, 2018 Report Posted May 6, 2018 PTK is correct.Sent from my LG-US996 using Tapatalk 1 Quote
Guest Posted May 6, 2018 Report Posted May 6, 2018 Doesn’t it depend on what country his airplane is registered in? FAA rules won’t apply if his plane is registered in Germany. Clarence Quote
flumag Posted May 6, 2018 Author Report Posted May 6, 2018 (edited) Thanks Peter, if thats the way than its easy. Clarence, you are right. EASA would be scared, but I'm fine since I moved my M20K to an FAA registration. This was also necessary for the avionic upgrade and the second alternator. Hendrik Edited May 6, 2018 by flumag 3 Quote
ZFD Posted May 8, 2018 Report Posted May 8, 2018 Question for Clarence: Would this type of modification be approved by Transport Canada? Thanks Bruce Quote
Guest Posted May 8, 2018 Report Posted May 8, 2018 18 minutes ago, ZFD said: Question for Clarence: Would this type of modification be approved by Transport Canada? Thanks Bruce As we have no simple field approval process in Canada, I would say by STC would be the only way. Clarence Quote
KSMooniac Posted May 8, 2018 Report Posted May 8, 2018 As we have no simple field approval process in Canada, I would say by STC would be the only way. Clarence Why can't you replace one TSO part with another? Sent from my LG-US996 using Tapatalk Quote
Guest Posted May 8, 2018 Report Posted May 8, 2018 Just now, KSMooniac said: Why can't you replace one TSO part with another? Sent from my LG-US996 using Tapatalk You can, but the original poster said that his K model wasn’t on the AML Clarence Quote
KSMooniac Posted May 8, 2018 Report Posted May 8, 2018 TSO implies you don't need an STC/AML doesn't it? STC is needed if the hardware doesn't meet TSO or other existing standards if my memory is correct. All those vintage TSO radios never needed an STC for installation as an example.Sent from my LG-US996 using Tapatalk Quote
bradp Posted May 8, 2018 Report Posted May 8, 2018 It’s is also of similar form fit and function to the original part, has a TSO, has a PMA, is cross referenced in the Whelen catalog, and is installed in accordance with 43.13 Chapter whatever that seems like it passes the approved data sniff test. Thus no STC needed. No 337 needed. It is definitiaonaly not a major mod, so seems to land firmly in the category of minor / logbook entry. 3 Quote
Gary0747 Posted May 13, 2018 Report Posted May 13, 2018 (edited) Were you also able to remove your belly beacon as part of this install? Which is the better system the Orion 650 or 600? Edited May 13, 2018 by Gary0747 Quote
FLYFST Posted May 20, 2018 Report Posted May 20, 2018 I think it can be installed as a minor modification, so only needs an AP signature. Talk to your mechanic. Just replaced my two wing strobes and nav lights on my 1990 J with the Orion 650e and my A&P agreed the only documentation needed was a logbook entry. Sent from my iPad using Tapatalk Quote
flumag Posted May 21, 2018 Author Report Posted May 21, 2018 J was clear since its part of the STC. K was just not part of the STC Hendrik Quote
Bryan Posted May 21, 2018 Report Posted May 21, 2018 16 hours ago, Aviator4Life said: Just replaced my two wing strobes and nav lights on my 1990 J with the Orion 650e and my A&P agreed the only documentation needed was a logbook entry. I had a 1982 M20K 231 that I replaced all the nav/strobes, tail, and beacon with the Whelen LEDs (650E, 500, 90520) and My A&P/AI just documented with a logbook entry, too. All my old ballasts came out saving me some UL# and we also ran the sync wire for the three strobes. The LEDs were way brighter and much less strain on my electrical system. Quote
OR75 Posted May 21, 2018 Report Posted May 21, 2018 I don't see the J model on the STC Can anyone point to a document ? Quote
KSMooniac Posted May 21, 2018 Report Posted May 21, 2018 You don't need an STC or 337. These are TSO lights that can be installed as a minor mod with a logbook entry.Sent from my LG-US996 using Tapatalk Quote
