Anyone happen to know if the eagle has a cigarette lighter and where.  Im picking my eagle up tomorrow and expecting to be at least 6 hours in the plane and charging my phone and ipad would be great.
Thanks Nik
5 minutes ago, steingar said:
Mine won't charge the iPad, I haven't tried the phone yet.  It will charge the Stratus.
Where is it? I cant find it on the panel? Ive looks it up online and either im blind or just oblivious.
Mine has one and with the right adapter charges  my iPhone and iPad.   I can plug in the stratus and it works fine.   Eagle is 28 volts but my cig lighter adaptor converts it to 12 volts.
8 minutes ago, M20S Driver said:
Right above throttle and prop.  See pic.
That explains a lot. Mine doesnt have it. No wonder i couldnt find it
On 4/20/2018 at 4:00 PM, kmyfm20s said:
My is to the right of the flap switch underneath the panel. The panel facing co-pilots legs.
Is that it?
this or something like it will charge the ipad a few times. i own one.  I have found in cruise there isnt much need for an ipad, turning off the screen makes it last all day.
https://www.amazon.com/Anker-PowerCore-20100mAh-Portable-Compatible/dp/B01LQ81QR0/ref=sr_1_1_sspa?ie=UTF8&qid=1524285835&sr=8-1-spons&keywords=power+bank+anker&psc=1
Well thats the exact plane im flying home tomorrow so i know where it is now. Thanks and sorry for my inability to find something so simple.
Yes, I pulled the picture from the ebay ad that I had shared on the post where you were looking for an Eagle. I hope that's a cigarette lighter socket in the picture. It looks like it though. Best wishes on the return trip in your new Mooney!
You need a 2 amp USB adapter to charge an iPad or even to keep it charged.
So now we know where the socket is...
1) Be sure to know what voltage it is being served...  the plane is 28v, but some Moonies have a transformer to deliver 12v to the socket.
2) If it is a 28v socket be sure you have a USB plug that can handle both 12 and 24v...
3) If you have only one socket, you might to have one of those splitter devices to feed a couple different portable devices.
4) An extra USB battery makes a lot of sense.
5) Nothing like guessing everything will work out right.... have a Plan B and a Plan C...
My ‘94 O has only one socket @28V...
That ended up not being the socket. it was a data port. the plane doesn't have a socket.
I fly with 2 spare batteries no matter where I go.
our flight plan didn't work out. ended up getting stuck in dodge city, Kansas KDDC. A lot of hiccups on the flight too.
some scarier than others. but one thing I can say.
THAT IS ONE FAST AIRPLANE.
