PT20J Posted February 7, 2020 Report Posted February 7, 2020 21 minutes ago, Vance Harral said: It's obvious from some reading that steel helicoils are inserted into aluminum structures all the time. But isn't this a galvanic corrosion risk? No. First, steel and aluminum are not that far apart on the galvanic chart. Also, while the aluminum is the anode and would be expected to corrode, the area of the anode (aluminum) is so much greater than cathode (steel) that the effect is negligible. This is why you can use stainless steel screws to attach aluminum inspection panels. Skip 2
Guest Posted February 7, 2020 Report Posted February 7, 2020 5 hours ago, Vance Harral said: It's obvious from some reading that steel helicoils are inserted into aluminum structures all the time. But isn't this a galvanic corrosion risk? Most Helicoils that I’ve encountered have been stainless steel. Clarence
Vance Harral Posted February 8, 2020 Report Posted February 8, 2020 26 minutes ago, M20Doc said: Most Helicoils that I’ve encountered have been stainless steel. I'm sure @PT20J is correct that the galvanic corrosion concerns are negligible. But for what it's worth, stainless steel is a little further away from Aluminum on the galvanic corrosion chart than mild and chromium steel, and therefore technically more susceptible to the galvanic corrosion problem, not less: https://www.albanycountyfasteners.com/blog/2017/09/15/stainless-steel-and-aluminum/ My understanding is the "stainlessness" of stainless steel refers only to its resistance to iron oxide corrosion from water and/or most air. It's not necessarily better protected than non-stainless steel from adjacent metals or other non-atmospheric elements. That said, I'm not a materials expert and maybe I'm off base here. Happy to be educated by people with a better understanding.
Guest Posted February 8, 2020 Report Posted February 8, 2020 25 minutes ago, Vance Harral said: I'm sure @PT20J is correct that the galvanic corrosion concerns are negligible. But for what it's worth, stainless steel is a little further away from Aluminum on the galvanic corrosion chart than mild and chromium steel, and therefore technically more susceptible to the galvanic corrosion problem, not less: https://www.albanycountyfasteners.com/blog/2017/09/15/stainless-steel-and-aluminum/ My understanding is the "stainlessness" of stainless steel refers only to its resistance to iron oxide corrosion from water and/or most air. It's not necessarily better protected than non-stainless steel from adjacent metals or other non-atmospheric elements. That said, I'm not a materials expert and maybe I'm off base here. Happy to be educated by people with a better understanding. Like you I’m not a materials expert, all I can offer is experience based on more than 3 decades of GA maintenance and I’ve never seen corrosion between aluminum and Helicoils. Clarence
PT20J Posted February 8, 2020 Report Posted February 8, 2020 46 minutes ago, Vance Harral said: I'm sure @PT20J is correct that the galvanic corrosion concerns are negligible. But for what it's worth, stainless steel is a little further away from Aluminum on the galvanic corrosion chart than mild and chromium steel, and therefore technically more susceptible to the galvanic corrosion problem, not less: https://www.albanycountyfasteners.com/blog/2017/09/15/stainless-steel-and-aluminum/ My understanding is the "stainlessness" of stainless steel refers only to its resistance to iron oxide corrosion from water and/or most air. It's not necessarily better protected than non-stainless steel from adjacent metals or other non-atmospheric elements. That said, I'm not a materials expert and maybe I'm off base here. Happy to be educated by people with a better understanding. There are a couple of ways to make "stainless" steel": passivated and non-passivated. Passivated is preferred if you are trying to prevent corrosion of the stainless steel part (rust) because it makes the material surface less susceptible to corrosion. Non-passivated is preferred if you are trying to prevent galvanic corrosion from contact with another material -- in our case aluminum. From the Helicoil manufacturer's application note: http://www.olander.com/contentonly.aspx?file=images/corrosionhc68 1r5.pdf Note: 18-8 Stainless (Active) is much closer to aluminum and magnesium than the Passive stainless. The conclusion is logically made that using passivated stainless steel will accelerate the corrosion of all metals above it. This is one reason why Stainless Steel Heli-Coil® Inserts are not passivated. Bottom line: Materials engineers have figured all this stuff out so we don't have to. Helicoils are safe to use in aluminium. Skip 3
PT20J Posted February 8, 2020 Report Posted February 8, 2020 26 minutes ago, M20Doc said: Like you I’m not a materials expert, all I can offer is experience based on more than 3 decades of GA maintenance and I’ve never seen corrosion between aluminum and Helicoils. Clarence Only 3 decades? With all your knowledge, I'd have figured you for 5 decades -- at least. 3
carusoam Posted February 8, 2020 Report Posted February 8, 2020 Passivation is an interesting surface treatment process for SS... Once the parts are made, the finished surface gets treated to remove the easily oxidized molecules near the surface... in simplified cases, citric acid washes are used... get out the lemons... An important pre qualification step before using SS tanks in the pharma industry... PP thoughts only, not a chemist or material scientist... Best regards, -a-
highflyer77 Posted April 15 Report Posted April 15 Dear folks, I´d like to bring this up again, as also with my M20E I have ripped off tie down rings. So far, I have helped myself by using the main gear to tie down my plane. But it would be nice to be able to use the tie down rings again... According to the comments here it should be no problem to repair this with 5/16 helicoils, or to use the LASAR-tiedown/jack-combo. BUT: I have installed the Monroy-STC long range fuel tanks (86 gals. of fuel). Now I am frightened to open a panel, as I am not sure, if the specific one next to the tie down ring hole is part of the sealed outer fuel tanks... on the other hand, I do not want somebody to drill into the wing for installing a helicoil, as I am frightened that this also can cause leakage of my outer tanks... I would be happy to get qualified answers from the expert´s here, maybe even somebody has pictures that would help ... Thank´s to all in advance !
Pinecone Posted April 15 Report Posted April 15 To use the LASAR ring/jack point, you can also do the helicoil fix without opening any panels.
Fly Boomer Posted April 15 Report Posted April 15 2 hours ago, highflyer77 said: with my M20E I have ripped off tie down rings I would be interested in knowing how those threads were compromised. Might be worthwhile to have a Mooney-specific mechanic examine that area inside the wing.
Yetti Posted April 15 Report Posted April 15 2 hours ago, highflyer77 said: Dear folks, I´d like to bring this up again, as also with my M20E I have ripped off tie down rings. So far, I have helped myself by using the main gear to tie down my plane. But it would be nice to be able to use the tie down rings again... According to the comments here it should be no problem to repair this with 5/16 helicoils, or to use the LASAR-tiedown/jack-combo. BUT: I have installed the Monroy-STC long range fuel tanks (86 gals. of fuel). Now I am frightened to open a panel, as I am not sure, if the specific one next to the tie down ring hole is part of the sealed outer fuel tanks... on the other hand, I do not want somebody to drill into the wing for installing a helicoil, as I am frightened that this also can cause leakage of my outer tanks... I would be happy to get qualified answers from the expert´s here, maybe even somebody has pictures that would help ... Thank´s to all in advance ! I think if you look the tie down is in line with the gear which is behind the fuel tanks. The Monroy tanks extend the fuel tanks further out the wing. The fuel tank panels are flatter and more streamlined than the panels you can remove. The panel for the tie down ring is behind it. The aluminum that is threaded for the rings is pretty thin. I just opted for a nut and permanent rings/jack stands. 1
Ragsf15e Posted April 15 Report Posted April 15 3 hours ago, highflyer77 said: Dear folks, I´d like to bring this up again, as also with my M20E I have ripped off tie down rings. So far, I have helped myself by using the main gear to tie down my plane. But it would be nice to be able to use the tie down rings again... According to the comments here it should be no problem to repair this with 5/16 helicoils, or to use the LASAR-tiedown/jack-combo. BUT: I have installed the Monroy-STC long range fuel tanks (86 gals. of fuel). Now I am frightened to open a panel, as I am not sure, if the specific one next to the tie down ring hole is part of the sealed outer fuel tanks... on the other hand, I do not want somebody to drill into the wing for installing a helicoil, as I am frightened that this also can cause leakage of my outer tanks... I would be happy to get qualified answers from the expert´s here, maybe even somebody has pictures that would help ... Thank´s to all in advance ! I feel your nerves! I just had my annual and beforehand I put blue painters tape on every fuel panel under the wing with a big “NO” on it! There are a couple monroy ones that are easier to miss as they used to be normal, removable ones with the little holes in the middle. If you look closely for sealant and tap them and look down from inside the monroy tanks you can tell which ones are fuel.
IvanP Posted April 15 Report Posted April 15 2 hours ago, Fly Boomer said: I would be interested in knowing how those threads were compromised. Might be worthwhile to have a Mooney-specific mechanic examine that area inside the wing. Most likely by someone with the "if it does not fit, get a bigger hammer" attitude who was replacing the tiedowns after jacking the plane up for maintenance. My plane suffered the same injury a while back. Apparently, it is not that hard to cross-thread and strip the thread for Mooney tiedowns. Helicoil and Lasar permanent jack point/tie down combo fixed the issue for good. 1
highflyer77 Posted June 30 Report Posted June 30 I checked again, and as I have installed the Monroy STC, exactly the one access panel that obtains acces to the side of the spar, where I could reach the area of the hoist point, is sealed... any ideas from the real experienced Mooniacs, how I could get this problem solved ?
