RobertGary1 Posted February 28, 2017 Report Posted February 28, 2017 Just got an estimate from a local avionics shop for a G5 install. They're estimating 15-20 hour work. So about $2500 in labor for a total of about $5000. Does that sound common? -Robert Quote
Godfather Posted February 28, 2017 Report Posted February 28, 2017 G5 or G500 ? No IMO that is way too high. I'm guessing you need the antenna which might add a few hundred in both hardware and install. I'm buying one and planning on $2500 installed. Quote
RobertGary1 Posted March 1, 2017 Author Report Posted March 1, 2017 That's what I'm trying to figure out. One place told me I didn't even need the external GPS antenna if I didn't care about track. So hook to power, ground pitot and static. It seems like an hour or two. What an I missing? Is there calibration, etc? -Robert Quote
Godfather Posted March 1, 2017 Report Posted March 1, 2017 Per the stc you need to have gps data to be certified. For the non certified you can use the internal GPS receiver. Quote
air cooled dad Posted March 1, 2017 Report Posted March 1, 2017 (edited) Just picked mine up from the avionics shop a couple days ago. $2900 total. Tax, install, G5, fiddled with my old kx170b, updated my gns430 and even wired my JPI830 up to my gps. Edited March 1, 2017 by air cooled dad Quote
Joe Larussa Posted March 1, 2017 Report Posted March 1, 2017 6 hours ago, RobertGary1 said: Just got an estimate from a local avionics shop for a G5 install. They're estimating 15-20 hour work. So about $2500 in labor for a total of about $5000. Does that sound common? -Robert For better or worse that's what it cost me. 1 Quote
NotarPilot Posted March 1, 2017 Report Posted March 1, 2017 I paid $680 to have mine installed and that required a little extra work of him filing out the hole to make it fit above the HSI. Quote
N6758N Posted March 1, 2017 Report Posted March 1, 2017 Even with running new power/ground and hooking up to GPS source it should be no more than 8 hrs labor; so maybe $6-800 should be a reasonable amount of time. Quote
Bob - S50 Posted March 3, 2017 Report Posted March 3, 2017 (edited) Don't know where you are located, but I asked our guy at Spencer's (Puyallup, WA, KPLU) and he said about 2 - 4 hours to install. I'm sure it is more if you need another GPS antenna too. Edited March 3, 2017 by Bob - S50 typo 1 Quote
